Products => Test Equipment => Topic started by: jman on February 23, 2016, 05:54:59 am
Title: Help with PCB ELECTRICAL TEST
Post by: jman on February 23, 2016, 05:54:59 am
Hi Everyone,
what brand of Test Equipment is good for testing the PCB at High Voltage (Test the Insulation between points)
i'm not sure what type of test equipment i need for this. is it HIPOT Testing?
Title: Re: Help with PCB ELECTRICAL TEST
Post by: Neilm on February 23, 2016, 07:35:03 pm
Basic question - what voltage? 100V? 1000V? 10kV
Post by: jman on February 24, 2016, 09:03:08 am
Voltage Range from 0-3KV (Max 5KV)
Thanks in advance
Post by: Rerouter on February 24, 2016, 10:03:25 am
the most generic item you could find for that, would be a variable output "megger" aka insulation resistance tester,
