Products => Test Equipment => Topic started by: picitup on February 03, 2018, 01:32:42 pm
Hi All
I'm trying to drive the timebase of my DS4014E from my BG7TBL gpsdo and am unable to convince myself it's working.
The documentation for this feature is very poor and after a number of emails to Rigol I managed to extract from them that the external clock is 10MHz, 1-4vpp square or sine wave and is a high impedance input.
However, after connecting the gpsdo to the external clock BNC at the back, I chose the Utility menu, RefClock and ClockInput but I can't see any indication it's working. There doesn't seem to be any display annunciator to show it's external and the 10MHz hardware counter shows 10.0000 MHz both on Internal and external clock.
Also if I choose the Horizontal menu on the left and add a Frequency label, the readings dance around between 9.96 and 10.04 MHz.
Has anyone successfully proved the 10MHz external input works?
I'm letting it cool down now and will try again later with the internal clock and the GPSDO and maybe the frequency will be off a bit when it's cool and internally clocked and perfect if it's switched to external.
I must admit that with the poor documentation, difficulty extracting the specs from Rigol and unable to see any changes it makes me wonder if it works at all.
Cheers
Steve
Well I think I've just realised my fears. I don't think the 10MHz input works. When I select the external clock, I can hear the reassuring clunk of a relay, but that's not helping much.
I just connected my SDG1025 sig gen to the external input and a 10MHz gpsdo signal to CH1 and turned on the hardware counter.
The sig gen was set to 10MHz sine wave @3.3v pp and the scope displayed the sine wave from the gpsdo and the scope freq. counter displayed 10.0000 MHz.
I then adjusted the frequency of the sig gen slowly down to 9.5MHz. I expected the sine wave and frequency counter to change with the incorrect external reference frequency but no change. I tried adjusting the sig gen output to 3.9v, tried a square wave and tried adjusting the frequency down to 1MHz and up to 15MHz but no change.
So I think it's buggered. >:( As a point of interest, if you set the clock to external on the sig gen and unplug the connection, it provides no output which makes sense, I think. On the scope if you set it to external and unplug the cable, it all works fine and there's no visible change.
Has anyone actually got this working? Am I missing something?
Steve
I tested the external sync on my DS4054.
* Connected 9.999MHz sine at 3.3Vpp to CH1.
- Display shows nice sine wave.
- Hardware counter shows 9.99903MHz.
- As expected.
* Enabled external reference as input and connected the same 9.9MHz to external reference input.
- Display shows attenuated and distorted signal. More a triangle wave than sine.
- Not expected. Did not expect the reference input to distort its input. Expected the hardware counter to show 10.0000MHz.
* Disconnected the 9.999MHz signal.
- Display shows no signal.
* Enabled external reference as output.
- Display shows a distorted 10MHz square wave at 2.6Vpp. The distorsion of the square wave is similar to the distortion added when the external reference is an input.
So, the external input distorts the connected reference and does not lock to it. It can't even produce a clean reference output. Completely broken.
I had similar doubts but found the external ref input to work (at least most of the time...). I'm using a +7dBm, transformer coupled Rb source (no risk of ground loops). I found the internal reference of the oscilloscope (MSO4014 "+") to be quite jittery, so loooong trigger delays will result in difficulties to get a stable waveform. The DS1054Z and the DS2072 are much better in this regard. But as I connect the external reference, the waveform goes stable within a second or so. And that's not related to the signal source possibly being affected by an unstable external reference since the source was running off its (apparently quite decent) internal oscillator.
So yes, the external reference input is working (at least on my unit) but the scope doesn't notify of the reference source being used -- room for improvement!
I think all the rigol gear with external ref inputs check the signal for "plausibility" before it actually gets used.
Cheers and good luck,
Thomas
Hi Both
Thanks for taking the time to try it out :-)
@glarsson it sounds like your input does work, but not properly. On yours if you disconnect the ref clock in you lose display which is expected and on mine, the display works just fine with the ref clock disconnected.
I didn't think of connecting the 10MHz output to a channel, but just tried this. The result is a slightly grubby square wave at 10MHz at 1v pp which is a bit low, I think. Also the frequency label from the left menu dances around between 9.996 and 10.04 MHZ which is a bit weird if it all comes from the same timebase.
@TurboTom thanks for the info. Yes I agree there should be an icon on screen but I think I might know why there isn't.....
Probably cynical but I think they've had a problem with the design and what they have done with my scope is make the ref input inactive, just connected to the internal timebase and an icon would show that you weren't connected. Given the background and poor documentation and extracting info from Rigol about the electrical specs implies to me they know there is an issue.
I wonder how many users think they are running ext ref input when actually they are running internal timebase.
I'll give them a call tomorrow. I don't want to send it back, but hope they can fix it. See if I can get them to confess. I'll report back what their response is.
Cheers
Steve
Just another quick test. I connected the clock output the ds4014e to my TF930 counter which in turned is clocked with the gpsdo.
The output at 10MHz was 5Hz high so 0.5ppm. I had expected a little better. Does anyone know what kind of xtal is in the scope? Is it possible to do a closed case calibration? It doesn't seem good enough for an OCXO.
Cheers
Steve
The DS/MSO doesn't utilize an ovenized oscillator, at best it's temperature compensated (TCXO). I just did some tests with my MSO4000 and only can confirm that the internal reference is crap. Mine is also running high by slightly more than 5Hz but what's even worse is the jitter. Please see the photos of my HP53310A's MDA analyzing the MSO4000 Ref Out signal. The MDA received its reference from my Rb standard so compared to the oscilloscope, this could be considered spot-on.
This reference jitter of the MSO4000 manifests itself as an unstable trace when running the scope with delayed timebase. To visualize this, I attached two more photos (sorry, didn't have a thumb drive handy in the basement to take a"proper" screenshot so I just used the cell phone camera...), both taken with trace persistance set to infinite so all the "jittery" traces remain visible, the 10MHz reference output of the MDA (this time free-running, i.e. not sync'd to the Rb source) used as input signal to the 1st channel of the oscilloscope and the timebase delayed by 100ms. The first photo is taken using the scope's internal reference, the second using the external Rb reference.
One peculiarity is that at least my MSO4000 wouldn't properly lock on the external reference if I first select the EXT REF connector (->Utility->PG_Dwn->REF...) to operate as an input and then connect the source; it's got to be the other way round instead, first connect the stabilized source and then switch the EXT REF connector from output to input.
Seems like Rigol thought that nobody would ever use the external reference connector on a scope... anyway, there's no reason for using such a piss-poor reference source in one of their more expensive scope models, as I already mentioned before, both the DS1000Z and the DS2000A ranges perform way better in these regards.
Cheers,
Thomas
Here's a picture of the DS4k crystal looking a bit small for its pads: https://photos.app.goo.gl/cWrb1mVaAugpCG7Q2
Also, the 1GHz ADC clock lines are unterminated and largely floating. There's a lot of common mode noise, but I'm not sure how much that affects the jitter in practice. Maybe the internal 10MHz is bad enough that it doesn't make things appreciably worse ::)
Full album: https://goo.gl/photos/dxU3ChWUcvCMDW4N9
Hi Both
@TurboTom thanks for all the tests. Yes the jitter is crazy. So it looks like the internal clock is crap and the external clock doesn't work. More on this below.....
@jjoonathan thanks for the piccy. Yes that's certainly no OCXO although for my machine 0.5ppm isn't too bad although a bit worse than I might have expected for the price of the unit.
Well... I called Rigol in Germany and now I'm pretty pissed. The guy in tech support told me that the external 10MHz isn't used for the timebase, but it acts as a phase adjustment to phase synchronise different devices. I told him about my test of varying the input frequency and he confirmed that test would make no difference.
He confirmed there is no icon on screen to show the scope is using the external reference so I asked him how you can test if it's working. He says he has a pdf which he will email me and I'll post it up here if anyone else wants to play with it.
Did I mention I'm pissed? I spent ages looking for a scope of this calibre with an external 10MHz ref and it doesn't work in the way I expected. I might return it but then will have to start searching again.
Here's the info from the latest user guide:
This oscilloscope can output the internal 10 MHz sample clock signal from the [10MHz In/Out] connector at the rear panel as well as receive an external 10 MHz clock signal from the connector. This function can be used to synchronize multiple oscilloscopes. Press Utility and press RefClock to select the desired clock type.
ClockOutput: output the internal 10 MHz clock signal of the oscilloscope from the [10MHz In/Out] connector at the rear panel.
ClockInput: the oscilloscope receives the external 10 MHz clock signal from the [10MHz In/Out] connector at the rear panel.
I suppose it doesn't specifically say it controls the timebase, but it doesn't say not either. Have I been naive here or would others assume it would control the timebase?
Bummer. Bummer. Bummer.
Cheers
Steve
I Have to go out now, but the pdf has arrived so here it is.
Cheers
Steve
Steve -
the external reference input works (almost) as intended - at least on my MSO4014(+). I rather think that the internal reference isn't working properly, at least on my "4000". The problem very much looks like the early PLL configuration "oopsies" that Rigol messed up on the DS2000 and DS1000Z series and corrected by firmware update some time later. Yet, with the proper sequence of applying the external reference signal and configuring the 'scope, it locks perfectly stable on the external signal.
I tried to explain the procedure how to identify and correct the problem before but probably my contribution was a little bit confusing...
So here's a short video clip that I recorded today to show the behavior of my 'scope with internal and external reference. I would be glad if others could confirm or negate if their "4000's" show the same problem. Please be aware that to reproduce the problem, a decent, low-jitter frequency source (preferably in the 10MHz range) needs to be connected to the input and the 'scope's timebase has to be delayed by a long time compared to the period of the input signal -- I set the delay to 100ms.
Video: http://www.turbinemuseum.de/files/MSO4000_Clock_Jitter.mp4 (http://www.turbinemuseum.de/files/MSO4000_Clock_Jitter.mp4)
I also reversed input and reference source in order to find out within what frequency range the 'scope's PLL will lock -- my specimen does so within a range of 10.0MHz -50Hz +200Hz.
I hope this clarifies what I was trying to tell in my previous posts.
Cheers,
Thomas
Hi Thomas
Thanks very much for the video - I'm sure your explanation was fine, just me being dense :scared:
I ran your test and got the same results. Initially my trace showed heavy jitter and if I chose RefClock as ClockOutput and then ClockInput, the trace lost its jitter as it locked. If then disconnect the RefClock input, the jitter comes back as expected, but if you plug the cable back in again, it has no effect until you cycle ClockOutput/ClockInput.
Funnily enough, when doing the second test for the PLL, when reducing the frequency, if I went too far and it lost lock, I could simply increase the frequency and it would lock again as expected. However, when I increased the refclock frequency, when I went too high, it lost lock and would not recover by lowering the frequency. This time it required a ClockOutput/ClockInput cycle to recover.
To answer your question, when experimenting with RefClock frequencies mine would lock successfully at 10MHz -63Hz + 254Hz so is a little more forgiving than yours.
I'll have a play with the Rigol procedure later.
Cheers Steve
OK I just tried the Rigol procedure in the PDF above. The procedure works if you start with ClockOutput and switch to ClockInput. You can see the trace slide along to be in sync.
However, if you start with ClockInput, it does not work. If you then switch to ClockOutput then ClockInput it works. If you then switch the sig gen output off, it loses sync as expected, but switching the sig gen output back does not repair the loss of sync. To make it work, you have to cycle the clock out/in then it slides back into sync.
I tried a few different voltage measurements from 1 - 3.9 vpp and square an sine wave, but all worked in the same weird fashion.
In the guide it says within 6 seconds you should get a lock. I waited 30 seconds and nada.
I'm going to reply to the tech support guy and see what he says. They must be aware of this!
Cheers
Steve
Thomas, I was able to reproduce the jitter with a long timebase delay, but I don't have a precise 10MHz sinewave generator to compare. In my case, delays as short as 50us started to show a perceptible jitter. I suspect that is why my oscilloscope starts to fail decoding at larger streams (IIRC 200 or 500ms timebase).
One detail that I was curious: have you ever seen a low/mid end oscilloscope with an OCXO? (no, that does not excuse Rigol from having such jittery timebase)
You don't need a sine wave for doing these tests, a square wave signal will also do. Moreover, most cheap TTL / CMOS XTAL oscillators will do for testing, so you may possibly find something suitable in your "salvage box", at least for jitter testing. If you want to try to sync your o'scope on an external reference, of yourse you will need a fairly accurate 10MHz oscillator since the catch range is rather small as figured out by Steve and myself. But once again, if you're lucky, you may be okay with a 50 cents CMOS oscillator that happens to be running close to the center of its tolerance range.
I have never seen a 'scope with an OCXO, the best that it gets seems to be a TCXO. Oscilloscopes aren't meant for highly accurate time/frequency measurements and also the protocol decoders should be fairly tolerant to slight frequency errors or jitter. I'm really curious what Rigol got wrong in the DS4000 since even the most basic digital oscillator brick appears to produce way less jitter than this 'scope's timebase. I've got the impression that it's the same erroneous PLL configuration that caused the jitter on the DS2000 and DS1000Z, only that it hasn't been addressed yet. Shame on Rigol!
Cheers,
Thomas
Hi Thomas I've been trying to work out what the implications of a phase lock are vs an external timebase input. I know if it was an external timebase input, the frequency would be as accurate as my gpsdo, but for the phase lock - would that change the frequency of the timebase or just align a leading or trailing edge of the timebase.
What I'm asking is with a phase lock, would the timebase frequency be the same as the gpsdo?
Hope this makes sense lol
Cheers
Steve
Just a quick update on this. I took a couple of screenshots, one of the 10Mhz gpsdo with the scope's internal timebase and then phase locked on the ExtRef.
I think my jitter may be worse than yours! I'm going to post Rigol an old 555 timer I found on the floor in the shed and suggest they improve the timebase design >:D
Any road up, I'll send them an email now and report the issues with syncing to an external clock and the jitter and see what they say.
Cheers
Steve
Sorry but I couldn't resist this...
I realised you don't need an icon on screen to determine when it's in sync. If there's not 3 yards of jitter it's in sync :-DD
Keep Smilin'
Steve
The jitter looks spectacular in this setup, but do you really think a peak to peak jitter 0.2ppm of the delay time is that bad for a synthesized clock with a TCXO as reference?
From my experience, phase noise of a TCXO can be up to 40dB worse than a good OCXO for frequencies <100Hz distance from the carrier.
I would be really curious to see what you get when you actually phase-lock the DSO to a cheap external CMOS XTAL-oscillator.
Actually, I did it the other way round, locked my MSO4000 (EXT REF) to my Rb source and connected some salvaged TTL or CMOS XTAL oscillators (the old ones in the metal cans with DIL14 footprint and only pins 1, 7, 8 and 14 populated). I supplied the oscillators with 5V from my bench supply through 1.2m long alligator leads and no local decoupling (cannot get worse than this...). Frequencies that I tried were 60MHz, 20MHz and 16MHz (no 10MHz to be found in my "collection" and I didn't want to experiment with the "odd" ones...). Those three oscillators didn't produce any jitter like seen with the unstable PLL (TB delay 100ms). Of course, there was some sweeping visible while the oscillators heated up, but this was well-defined and came slowly to a rest as the oscillators reached thermal equilibrium. If I had found a 10MHz oscillator, I would have tried it at the REF input as well.
I guess the REF oscillator inside the Rigol 4000 series isn't that bad, it's got to be the PLL that's not properly set up to lock. You get the same jitter with a good external reference if the reference is connected after configuring the oscilloscope to use the external REF input. Yet, even if one proceeds in this sequence, the external reference has some effect on the timebase (a "jittery phase shift" can be observed in the signal displayed), it just doesn't stabilize.
And yes, both DS2000 and DS1000Z perform substantially better than 0.2ppm jitter in reference to the delay time.
Cheers,
Thomas
Thank you for the test. I am still wondering what's actually going on here. You think the TCXO is fine but the PLL refuses to lock properly. But…
- If the PLL is locked to the external reference clock, the jitter is gone. This proves the PLL works fine, once it's locked, doesn't it?
- If the scope works on internal reference, the jitter is there. From the conclusion above, we have to assume the PLL to be okay and you also think the internal TCXO is fine, so what's left? The PLL not locking properly on the internal reference? If so, why would it reliably lock on an external reference (after switching from int. to ext.) but never on the internal one (after switching from ext. to int.)?
I would rather speculate that PLL is fine, but there is some interference coupling into internal TCXO (basically FM modulation) or directly into clock signal on it's way to PLL... External signal might go different route and might avoid external signal coupling and won't have modulation being stable by itself...
The real peculiarity is that if the PLL locks on the external reference depends on the sequence of application of the external REF signal and enabling the external REF BNC as input.
1. External Oscillator on / connected
2. Switch BNC to REF input
-- Does Work
1. Switch BNC to REF input while the external oscillator is switched off or disconnected
2. Switch on / connect external Oscillator
-- Does NOT Work
What this means for the internal reference oscillator is something still left to find out. I think there's a good chance that the internal oscillator itself is okay. I guess I've got to disassemble the oscilloscope and do some testing with my spare scope and the SA to find out what's really going on. I'm only worried since my MSO4000 is equipped with the single big heat sink that covers all the digital circuitry. Without removing it, I cannot access the relevant areas of the PCB. If I remove it and operate the scope, I risk overheating and damaging the ADCs / FPGAs.
Cheers,
Thomas
Thanks to all for your replies. As usual, I'm learning loads :-)
Just for interest I've ordered a 10Mhz xtal oscillator from eBay for £2.98 item 400529955213 so I'll give it a bash when it arrives and report back.
No reply from Rigol yet, but it's only been a day. I'm away for a few days now but will try and log in. Here's the email I sent yesterday:
Hi Christian
I hope you are well. Thank you for the document. It took me a long time to get working due to an issue with getting the scope to sync with an external source. The issue is as follows:
If you select Utility/RefClock/ClockInput and connect the external reference it does not work. I tried 1v - 3.9vpp sine and square waves. If you then select ClockOutput and then ClockInput it works and the scope is in sync.
If you then turn external reference off, you lose sync as expected. Then turn the ext ref back on and the scope does not sync. To get it to sync again, you have to cycle ClockOutput/ClockInput with the external ref connected. Any interruption in the ext ref breaks the sync and can only be repaired by cycling as mentioned above.
The second issue I've come up with is a *HUGE* amount of jitter. I set the delay to 100mS and the screen persistence to infinite and took a screen shot. Then I synced up the scope with an ext ref and the jitter disappeared (see pictures).
I'm assuming these are firmware bugs. I did try to download the latest firmware, but it was dated 2016 and I bought the scope in October last year with the latest firmware. My scope details are:
Model: DS40142
Serial: ********
Software: 00.02.03
Hardware: 1.3
I'd be grateful if you could let me know if you have a fix for these 2 issues. Also, an icon of some kind on screen to show sync is achieved would be very helpful, otherwise it's a lot of guessing.
Kind Regards
Steve
Pictures are in previous post :-)
Well here's the reply from Rigol
Hi Steve,
please set the scope to normal trigger.
Christian
:palm:
I've replied saying I'm unhappy with the response so wait and see what he says.
Cheers
Steve
Well the 10MHz oscillator for £2.98 from fleabay arrived today so i thought I'd give it a go. As per previous tests, it work well as an external reference as far as the jitter goes which disappeared when it was connected. So a cheap as chips xtal has less jitter than the DS4000 series internal timebase lol.
I've not heard back from Rigol eu yet, but I'll give it a few more days and then escalate it.
One saving grace though, as discussed earlier, if you start the scope and THEN connect the ext ref, it doesn't lock, you have to cycle the clockout/clockin. However, if the extref was set to clockin the last time you turned it off, it will lock. so.... if you have your ext ref always connected and the extref to clockin it does lock during boot up. Pity there's no indicator on the screen >:(
I also tried different voltages for the ext clock and it actually works down to 100mV which is nice. Differing voltages from 100mV to 4V don't help the locking/jitter situation though.
Cheers
Steve
There's a new firmware for the DS4000 series available from Rigol's chinese download site: http://www.rigol.com/Support/SoftDownload/3 (http://www.rigol.com/Support/SoftDownload/3)
It is version 02.02.01.01 (02.03 SP1), released on August, 15 2017. Strange enough it apparently didn't show up un any english-language server. I tested it but unfortunately, regarding the problem discussed here in this thread, it wouldn't make any difference. Most notable change is that the vertical position controls are now dynamically accelerated which in my opinion is quite comfortable. Let's hope Rigol continues to support the firmware, also taking care of the clock jitter problem.
Cheers,
Thomas
Hi Thomas
Thanks for the link and info. I've downloaded the firmware and will install it later on today. I wonder what the "Storage Problems" were that have been fixed?
Well it's been 6 days now since I complained I wasn't happy with the answer from Rigol EU so I've knocked up an email for Rigol NA as follows:
Dear Sir/Madam
I wonder if you could help me escalate an issue with my DS4014E oscilloscope. I have been dealing with tech support at Rigol Europe but have been unable to make any progress.
There are a number of issues I am trying to address and here's a summary below:
1) Poor documentation for the external ref input
2) Difficulty making the scope phase lock to the timebase
3) Difficulty proving a the phase is currently locked
4) High jitter when using long timebase delays
I have been very pleased with the scope so far, in terms of price, features and value for money, but am surprised at the lack of support for the 10MHz ref input. I'll run through the list above in order:
1) Documentation
If you look at the product manual here:
https://www.rigol.eu/products/digital-oscilloscopes/4000/ (https://www.rigol.eu/products/digital-oscilloscopes/4000/)
The page deals with the reference clock. There are no electrical specs for the interface such as allowable voltage range, input impedance, frequency range, sine/square and so on. These specs would be very helpful.
2) Achieving phase lock
If you switch the scope on, switch the RefClock to ClockInput and then connect the external 10MHz reference, the scope does not lock. You have to change RefClock to ClockOutput then ClockInput and it then locks. If you then remove the 10MHz and plug it in again, phase lock is lost. You have to once again toggle ClockOutput/Clockinput and it locks again.
I've tried the above with a range of voltages from 1-3.9vpp and with sine and square waves and the result is always the same.
What I expected was to plug the external 10MHz reference in and the scope would phase lock without me toggling the RefClock. I don't feel very comfortable connecting two outputs together as I worry about damaging the equipment.
3) Demonstrating Lock is Achieved
There is no indicator on screen I can see to show that phase lock has been achieved. This would be very helpful, especially given the difficulties above. Just an icon or filled in circle or square would be great on the LCD.
4) Excessive Jitter
When using long timebase delays of, say 100mS, the jitter becomes excessive. I've attached a couple of screenshots for you to look at. The one with high jitter is the internal timebase measuring a 10MHz gpsdo signal on CH1. The one with no jitter is using the gpsdo as the external 10Mhz reference.
As a sanity test, I purchase a tin can 10Mhz crystal oscillator from eBay for under £3.00 and used this as the external reference in the same test. There was no discernable jitter so it seems a cheap oscillator has much less jitter than the DS4000 internal timebase.
I'm sorry this email is so long, but I wanted to include as much detail as possible. Hopefully all of the above issues could be dealt with in a firmware upgrade.
Kind Regards
Steve
Let's see what they have to say.
Well 20 minutes after emailing Rigol NA I got a message from Rigol EU. Coincidence? lol.
He's passed it on to Rigol China but it's the new year now till the 25th so there will be a delay in the reply.
I'll keep everyone posted.
Cheers
Steve
Well it's been a week since the end of the Chinese new year without a reply so I've given Rigol EU a nudge.
I'll post up any response.
Cheers
Steve
Well still no reply from Rigol EU and it's been another couple of weeks, so I've nudged again.
Cheers
Steve
I just read through the entire thread. The Rigol test seems to say that you should input a 3Vpp square wave into the Ext 10 MHz in but you said that your 10 MHz signal was only 1 Vpp - are you sure this isn't the issue?
I've been thinking about making a distribution Amp for my workshop so I can use my GPSDO, the design I'm favoring (https://www.briandorey.com/post/10Mhz-Frequency-Standard-Distribution-Project) has both sine and square wave outputs so clearly the 10 MHz in is not a standard thing, I've read that some people using 10 MHz square waves have problems with their equipment being confused by harmonics.
I just read through the entire thread. ...
Are you sure?
... plus some more quoted mentions ;)
The Rigol 10MHz Test pdf Document that picitup linked to is where I got that from - see picture.
Hi
Just to clarify I did try a range of voltages from 1-3.9vpp but it didn't change anything. There are also the issues of jitter and having to cycle the extref in/out.
I'm in Spain now lol so might be slow to reply.
Cheers
Steve
