Author Topic: Help with Siglent SDG1025 Ouputting "Pink Noise"  (Read 2203 times)
Offline TacheonTopic starter
« on: April 17, 2015, 06:53:30 pm »
Greetings EEV'ers and Dave, thanks for all you do down unda.
I just purchased a Siglent SDG1025 Func. Gen, and I like everything except the noise feature. I expected it to be "White" noise, and was simply going to run it through a passive filter to convert it to pink noise for audio testing. Unfortunately, I made the wrong assumption, and it turns out the unit outputs Gaussian noise, which doesn't work for me. I contacted the company, and they did attempt to provide me a spread sheet in .CSV format which was supposed to simulate pink noise. I loaded the file, but it seems that there is a sawtooth signal associated with it. I think it just might be number crunching it over and over, at the start point and I am seeing the math, but not sure. I wanted to use easywave software, and try to have the unit crunch an equation from the noise signal that the software provides, but I am not sure how to do that. Might anyone have an idea or work around on how to get this unit to output Pink Noise?
Here is a link for the equation: http://en.wikipedia.org/wiki/Pink_noise
Attached is a .CSV file from Siglent
Help?
Offline KennP
Re: Help with Siglent SDG1025 Ouputting "Pink Noise"
« Reply #1 on: June 30, 2017, 02:00:27 pm »
Hi Tacheon,
I'm just a Newbie so I don't know if you still need an answer to this question.
Anyway, my attempt at a solution was to change the CSV file using a fill down column formula like this;
=20*RAND()-10
I've attached the modified CSV
KennyP
"Say little about what you know and nothing at all about what you don't know."   Sadi Carnot
Offline coppice
« Reply #2 on: June 30, 2017, 03:57:37 pm »
"I wanted white noise, but I got Gaussian noise" makes no sense. The Gaussian noise will almost certainly be white. If you don't want Gaussian statistics, what are you looking for?
Offline KennP
« Reply #3 on: July 01, 2017, 09:09:37 am »
Doh! (as I slap my forehead). White noise has a flat spectral density, but in pink noise the frequency spectrum falls off as 1/frequency. I forgot to include that factor in my previous response, sorry. In fact the way I attacked the problem was a complete failure (sorry about that too).
The maths is too hard for me but interesting; See here http://www.firstpr.com.au/dsp/pink-noise/
« Last Edit: July 01, 2017, 09:32:43 am by KennP »
