Hello fellows!
Bought an Symmetricom DTI Signal Generator via eBay, has X72 Rubidium Standard inside and serial (RS-232) interface on the front side. Can't set any good parameters in terminal to view and write text. Have tried all speeds, 8 bits, 7 bits, stop bits, etc. Nothing works. Seems to use binary format? Has someone seen and/or configured this unit before?
Please help, want to correct the frequency, is slightly off by 6mHz to GPSDO.
best regards
Gregor
