Hopefully this is not just another company trying to drum up traffic to their site...
I´m looking for something... More details please.How much current (min, max/peak, duration), frequency, for what to use..
It probably is, otherwise an AC arc welder is a rather obvious choice.
So buying a welding transformer and feed him with a low/medium power source ist the cheapest way to gain the 400A current.
It does not seem like there are many accurate programmable ac current sources available.
For higher current simulations we use a transformer with one additonal winding on the core.We get nearly 100A this way while only 1A primary current is flowing.So buying a welding transformer and feed him with a low/medium power source ist the cheapest way to gain the 400A current.
Hmm, my 400A AC 2 phase stick welder cost me just $200.Duty cycle at full tit is another consideration fan cooled or not.
Quote from: freeelectrons on July 09, 2023, 07:11:57 pmIt does not seem like there are many accurate programmable ac current sources available. Oh yes there are! Pacific Scientific and Elgar just to name two of them. I don't know how high their current ratings are but they are very accurate voltage and frequency wise and they are programmable. I THINK you can also couple several Elgar units together to increase their current output and drive all of them from a single control module. What kind of voltage output do you need? 400 amps is a lot of current and if you need that amount at any significant voltage, it's going to be a hell of a lot of Power! If you just need a volt or two then you might be able to use an Elgar 251 or one of their 750 Watt models set to say 110 VAC and use that to drive a transformer that will give 400 Amps at 1/2 to 1 volt AC. I've used the Elgar 251s and some of the PS units and I know that Elgar makes a 750 Watt output model and I think they make larger models but I have no experience with them.
Quote from: Martin72 on July 09, 2023, 10:20:50 pmSo buying a welding transformer and feed him with a low/medium power source ist the cheapest way to gain the 400A current.Hmm, my 400A AC 2 phase stick welder cost me just $200.Duty cycle at full tit is another consideration fan cooled or not.
Quote from: Martin72 on July 09, 2023, 10:20:50 pmHmm, my 400A AC 2 phase stick welder cost me just $200.Duty cycle at full tit is another consideration fan cooled or not.Any links?
Older or not, full tit is usually always good...
Quote from: Martin72 on July 09, 2023, 10:20:50 pmHmm, my 400A AC 2 phase stick welder cost me just $200.Duty cycle at full tit is another consideration fan cooled or not.You can always parallel two welding machines, AC or DC. I have a couple of Millers that I've done that with a few times when using jet rods.It's a lot easier on the machines when they are sharing the load.WoD
Ever used a 400A welder running at full tit ?If not you are in for an experience.......300A is as hard as I've used and that ate 6g rods for breakfast !
