My Rigol scope screen looks fine when looking from slightly above. On-axis it looks not bad. If I put on a shelf above the bench just above eye level the screen contrast and visibility is nowhere near as good. I know some simpler LCD displays have some kind of contrast adjustment that you could alter to suit the viewing angle. I wish someone would do a hack to a Rigol scope to achieve the same thing.
