In one of Dave's videos he used his Agilent meter in high impedance mode. How does the input circuit look like for it? I would like to build something similar. My idea is to use a FET OpAmp in non-inverting mode as an input buffer, with +/-15V supply. This would allow me to measure +/-15V (minus some volts, depending on the OpAmp).
But would be nice if I could measure higher voltages as well. Should I use relays to switch between the direct input and a voltage divider, or is it possible to build a high impedance meter with higher input voltages as well? I would like to have at least 1GigOhm input resistance, and most CMOS switches have higher leakage, or cost a fortune, compared to a relay.
