Author Topic: Hioki 3237 5.5 digits meter teardown  (Read 2690 times)
Online coromonadalixTopic starter
« on: October 29, 2023, 01:58:03 am »
Just grabbed this on Fleabay, i was curious  of its internals
199999 count Bench DMM
Dac : Burr Brown  ADS1250U     20 bit ??
Next to it  IC22 :  An OPA2277        10µV, 0.1µV/˚C, High-Precision, Low-Power Operational Amplifier
Reference : An LT1027     thks @AVGResponding    Very Low Drift: 2ppm/°C Max TC Precision reference with extra-low drift
        For sure not the LM199 399 or even an LTZ1000  loll   :-DD
Main Cpu : Renesas H8S/2134F        Web says : Microcontroller for Office Equipment Applications
Eeprom i think  :  8 pins Soic    3771    if someone find a datasheet ???  i could try to read it ?
                                              0026
                                                343
ADC clock :  An EXO 3 clock module  18.432 Mhz  ??
Precision Resistor : Caddock 1776-C4
Display Drivers : 2x  TD62083F  8CH DARLINGTON SINK DRIVER
The front panel plastic is very thin / brittle, i dont think it would survive some impact,  sure its now yellowish
Under the pcb i only see some transistors, no other ic's,  i dont want to dismantle more than this
For sure they have put the cpu far away from the front panel ??
« Last Edit: October 29, 2023, 01:07:28 pm by coromonadalix »
Re: Hioki 3237 5.5 digits meter teardown
« Reply #1 on: October 29, 2023, 01:59:51 am »
Reserved
Seems more an ADC on steroids than a real meter ??
They exist as 3237, 3238, 3239    way overpriced for what they are ...
I did start a thread about Hioki calibrations ... but never got any responses
No schematics
Just some user manual and code snipets : Labview C# C++ Mathlab Python VBA
« Last Edit: October 29, 2023, 02:13:00 am by coromonadalix »
Offline dobsonr741
« Reply #2 on: October 29, 2023, 03:00:38 am »
The Manual - no schematics however.
The following users thanked this post: coromonadalix
Offline Martin72
  • Testfield Technician
« Reply #3 on: October 29, 2023, 10:32:29 am »
Hioki also consistently does not give out anything, and if the devices have not been manufactured for ages... :P
« Reply #4 on: October 29, 2023, 11:43:44 am »
some of theses 3237  goes down to 2001  ???
« Reply #5 on: October 29, 2023, 12:38:57 pm »
Reference : ????    have to check  For sure  not the LM199 399 or even an LTZ1000  loll   :-DD
The reference is the LT1027. Bit of a strange/old fashioned choice, but then that's Hioki...
https://www.analog.com/media/en/technical-documentation/data-sheets/1027fcs.pdf
« Reply #6 on: October 29, 2023, 01:04:52 pm »
Maybe they tried the best bang for the buck in thoses days ???
Haven't found a thing for the 8pins soic ic,  i do think it's an eeprom for the cal constants or more ??
OK Works so far  with Termite,  null modem cable
As per manual
*IDN?
HIOKI,3237,0,V1.10
So far,  nothing is shown on the rs232 port when the meter boot's up
« Last Edit: October 29, 2023, 01:35:40 pm by coromonadalix »
« Reply #7 on: November 30, 2023, 11:03:45 pm »
you have +8v and -8v symetrical supply (ic71 and ic72) and +5vdc (ic74) coming from the xformer secondaries / blue wires
around 7vdc for the 2 small xformer wires who goes on a rectifier bridge, and regulated (ic75)   at 5vdc  for the cpu section
blue wire pin 1 and 2 = 4.8 ohms
blue wires pin 3 4 5 =  3-5 = 14 ohms,    3-4 or 4-5 = 7 ohms
two small yellow "ish" wire = 0.9 ohms
some front pcb section ground is not common with othe meter ground sections, that's normal,  you have to know where your probing is grounded
« Reply #8 on: December 01, 2023, 04:36:05 pm »
I thought RS232 needed +/-15V or so?   :-//
I bet even with the somewhat odd choice of reference, it has pretty good performance.
Online Kleinstein
« Reply #9 on: December 01, 2023, 04:43:35 pm »
RS232 could be just OK with +-8 V, especially modern parts usually already accept +-5 V.  The old PCs used +-12 V.  New designs often use max232 or similar charge pumps to run of 5 V and create a voltage a bit under +-10 V.
Offline fzabkar
« Reply #10 on: December 07, 2023, 07:27:37 pm »
                                              0026
                                                343
MB3771 power supply monitor:
https://www.mouser.com/datasheet/2/100/002-08511_MB3771_Power_Supply_Monitor-931495.pdf
« Reply #11 on: December 07, 2023, 10:01:37 pm »
could be that one   THKS
if it is, i dont see on the pcb  where the calibrations would be stored, unless it's directly in the mcu ????
Offline fzabkar
« Reply #12 on: December 07, 2023, 10:15:15 pm »
H8S/2138 Group, H8S/2134 Group,
H8S/2138F-ZTAT™, H8S/2134F-ZTAT™,
H8S/2132F-ZTAT™
Hardware Manual
Renesas 16-Bit Single-Chip Microcomputer
H8S Family/H8S/2100 Series
https://www.renesas.com/document/man/h8s2138-group-h8s2134-group-h8s2138f-ztat-h8s2134f-ztat-h8s2132f-ztat-hardware-manual
I think I can see a NiCad (?) battery on the PCB. Maybe the settings are stored in RAM???
« Last Edit: December 07, 2023, 10:18:52 pm by fzabkar »
« Reply #13 on: December 08, 2023, 01:27:47 am »
no sorry  loll  the green one is a capacitor ... or a mov  due to its thickness,  but an input part  you see a line of resistors / voltage divider
and the black round thing 5A1 marking is the buzzer, had to put a tape on it,  very loud    loll
« Last Edit: December 08, 2023, 01:31:08 am by coromonadalix »
