Author Topic: Identifying and testing unknown antennas  (Read 2147 times)
Offline Shaw
« on: July 11, 2013, 02:04:43 am »
Hi all,
I've got a bunch of rubber-duck antennas at home in a box, I know some are 900Mhz and some are 2.4Ghz ones.  Of course they all look the same which is annoying.  Is there any simple way for me to test these?
I don't have a full electronics lab, but I do have a Rigol 100Mhz scope and multimeter... I don't have a signal generator or spectrum analyzer, which I suspect are the two pieces of required kit.
Any suggestions on a quick and easy way to identify these would be great.
Offline WarSim
« Reply #1 on: July 11, 2013, 02:52:37 am »
Without a signal generator or network analyzer, I can't think of anyway at the moment.
Offline Rasz
    • My random blog.
Re: Identifying and testing unknown antennas
« Reply #2 on: July 11, 2013, 03:00:26 am »
http://pe2er.nl/wifiswr/
or just get a wifi card and try all the antennas checking signal strength of a known ap
Offline vk6zgo
« Reply #3 on: July 11, 2013, 03:22:30 am »
Nice project,but being "rough as guts",I would go with your second suggestion! ;D
Offline WarSim
« Reply #4 on: July 11, 2013, 03:26:41 am »
I agree the second suggestion is much better than my no idea option.  :)
Offline olsenn
« Reply #5 on: July 11, 2013, 04:02:30 pm »
What are you trying to measure? SWR can be measured with a spectrum analyzer and a bridge or coupler. impedance can be measured with a multimeter or LCR meter, but it's safer if you measure this at the frequency you're operating at. More advanced measurements really call for a network analyzer and more specific equipment
Offline babysitter
  • pushing silicon at work
« Reply #6 on: July 11, 2013, 07:34:58 pm »
Look out for the local ham radio club. You might find that certain guy that loves to do exactly that, there.
I second the method of hooking it up to a Wifi card, and try to get the best estimation of field strength you can get -
with windows, netstumbler is your friend and wl under linux, I think.
Be careful when tightening the connectors.
I'm not a feature, I'm a bug! ARC DG3HDA
