Author Topic: How do I save History Acquisitions with Siglent SDS?  (Read 2817 times)
Offline kimitoTopic starter
  • Country: ar
« on: January 14, 2018, 03:58:28 pm »
Hi, I need support for my SDS2104X oscilloscope. I'm trying to save history and sequence acquisitions for further analysis with my computer, how can I do it? Thanks.
Offline rf-loop
Re: How do I save History Acquisitions with Siglent SDS?
« Reply #1 on: January 14, 2018, 04:55:27 pm »
Long time ago it works like this (I do not know at this time how most new versions looks and works). Output is .csv
You need use EasyScopeX
It goes somehow like this.
Look image (of course select right numbers what you want)
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
  • Country: ar
« Reply #2 on: January 14, 2018, 06:10:27 pm »
Thanks for your answer. I tried to use EasyScopeX in this way but I get an .csv file with 'n' waveforms equals to current frame shown in history mode. If you say that this way works, I suppose that my config has some problem.
Offline rf-loop
« Reply #3 on: January 15, 2018, 12:09:43 pm »
After some more look now, it looks like there is some bug. At this time I do not know if bug is in EasyScopeX or scope FW.
I will contact Siglent about it.
Offline sibir
« Reply #4 on: June 08, 2022, 06:09:14 pm »
It's been 4 years. Is there still no other/better way to save a sequence history from an SDS scope?
