Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
How do i test a ic that produces a square wave with a scope?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How do i test a ic that produces a square wave with a scope? (Read 2988 times)
Jesset1996.5
Regular Contributor
on:
September 17, 2015, 12:31:52 am »
Hello everyone! I currently have an ic that goes in my powe supply that needs to be tested. It produces an square wave and i know i can measure it with a scope but im not quite sure how.
i have looked on the Internet but all that pops up is using a signal generator which is useless info since what i am testing is if the ic produces a square wave or not. The square wave is fed into a transistor to boost the voltage from 12v ac to 45v ac to charge some caps that rase it to 110v ac. The transistor self destructed itself and i think it may have been due to ether something wrong with the ic or even just its age. How exactly would i set up this kind of test up? I am new to using scopes so any help would be great!
Last Edit: September 17, 2015, 12:34:22 am by Jesset1996.5
Logged
JoeB83
Regular Contributor
Country:
Longmont, CO
Re: How do i test a ic that produces a square wave with a scope?
Reply #1 on:
September 17, 2015, 01:37:35 am »
What is the IC? Find the datasheet, look for the output pin, and connect your probe to the output pin.
Logged
DimitriP
Super Contributor
Country:
"Best practices" are best not practiced.© Dimitri
Reply #2 on:
September 17, 2015, 02:52:23 am »
Logged
If three 100 Ohm resistors are connected in parallel, and in series with a 200 Ohm resistor, how many resistors do you have?
JoeB83
Regular Contributor
Country:
Longmont, CO
Reply #3 on:
September 17, 2015, 06:58:21 am »
Quote from: DimitriP on September 17, 2015, 02:52:23 am
You should be set!
Logged
tggzzz
Super Contributor
Country:
Numbers, not adjectives
Reply #4 on:
September 17, 2015, 07:11:02 am »
And with that probing technique you are likely to see edges like this (or worse)
https://entertaininghacks.files.wordpress.com/2015/03/hp10074-falling-6inch.gif
when the waveform is actually like this
https://entertaininghacks.files.wordpress.com/2015/03/hp10074-falling-bayonet.gif
Logged
Glider pilot's aphorism: "there is no substitute for span". Retort: "There is a substitute: skill+imagination. But you can
buy
span".
Having fun
doing more, with less
Jesset1996.5
Regular Contributor
Reply #5 on:
September 17, 2015, 10:24:17 am »
the ic is a cn587t. I cant seem to find a data sheet or even a ic i can use to substitute the ic with if it doesn't work.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
