Author Topic: How many time can I physically connect and disconnect a hard drive?  (Read 1479 times)
Offline electronbeanTopic starter
Hello everyone,
I intend know how many time could I attach and detach a hard drive on drive bay HDD like this: https://www.newegg.com/orico-1106ss-v1-bk-1-x-3-5-drive-to-5-25-bay/p/0VE-000W-00018?Description=5.25%20hard%20drive%20bay&cm_re=5.25_hard%20drive%20bay-_-9SIA1DS0FS5106-_-Product
I need put on hard drive and push outside the hard drive when my job is finish. I do this around 10 time for month. In a year will be 120 times. I am concerning with connectors SATA data and SATA power on hard drive. Could I will get problems, like bad connections, cold welding or another issues?
I search about datasheet of the hard drive I found this: https://documents.westerndigital.com/content/dam/doc-library/en_us/assets/public/western-digital/product/internal-drives/wd-blue-hdd/product-brief-western-digital-wd-blue-pc-hdd.pdf
But this document didn't refer information about how many time I can physically connect and disconnect the hard drive.
Thank you
Offline coromonadalix
for sure there is a limit to contacts wear ............  but in this occasion,  i use trays with included power switches in the enclosure   loll
Still going strong after years
But for sure you're in need to remove it as a safety,  only thing i can say
For other guys i know:  after a thousand insertion the tray is ditched,  and others say after 500 inserts ...
Maybe this ?
https://www.reddit.com/r/DataHoarder/comments/inzo2g/hdd_sata_port_durability/
or this :
How durable are SATA connectors?
The connectors are SATA compliant and meet a wide range of vertical and right angle configurations for usage across server and storage equipment, HDDs and HDD carriers. Durability: 500 mating cycles ▪ Mating Force: 45N max.
« Last Edit: May 20, 2023, 01:37:21 am by coromonadalix »
Offline Georgy.Moshkin
  • Country: hk
  • R&D Engineer
    • How to become a Tech Sponsor
I had similar question and I thought of using these or similar products (see attached image). Moreover, my old notebook had an sata to sata extension pcb, somethimg like that could help to transfer wear off from hdd connector to extender connector
Disappointed with crowdfunding projects? Make a lasting, meaningful impact by becoming a Tech Sponsor today. Visit TechSponsor.io to Start Your Journey!
Offline GigaJoe
such kind of connectors usually around 500-1000 inserts
Offline David Hess
  • DavidH
It will depend on how good and thick the surface plating is on the connector surfaces.  The minimum specification for SATA is something like 50 insertion cycles, however I would expect 100s of cycles if not abused.  Unfortunately there is a lot of variation in quality from various suppliers so there is no way to really know.
Offline Hydron
We run into this where I work doing sneakernet with SATA SSDs, I know they eventually fail - will ask the ops folks how long they normally last. I suspect the hot swap racks fail before the drive connectors - they get more cycles and have the spring terminals Vs the drive with the fixed wafer.
Offline KungFuJosh
  • TEAS is real.
You can cheat if you're using a SSD or a 2.5" drive. You can install the smaller drive into a 3.5" adapter then all the wear and tear is on the adapter, not the drive.
The following users thanked this post: Georgy.Moshkin, Wrenches of Death
Offline JeremyC
Hello everyone,
Thank you
Ha, interesting question. But wouldn’t be easier to use a USB3 caddy? Those run for ~$15, and in worst case the USB connector will worn out.
Since 15+ years I use this technique frequently (even with mini-IDE before the SATA era), mostly on the client site to run virtual machines.
