Author Topic: RIGOL Launches RSA5000 Series, the First Real-Time Spectrum Analyzer in China  (Read 14688 times)
Offline simone.pignattiTopic starter
from the user manual:
Scale/Div (PvT)
Sets the unit per division in the vertical axis of the PvT view. Note that this menu is only valid in PvT measurement mode.
Technical Support
Offline Mr. Scram
  • Display aficionado
Maybe this amazing product shot from their European site gives a clue. There's some serious parallax going on here...
https://www.rigol.eu/real-time/
The Photoshop fails are frankly hilarious.
still!!?? I told them few days ago, I'll report again, thanks.
Technical Support
Offline Mr. Scram
Don't worry, it looks fixed. I was talking about the original mistakes. I can come up with various amusing scenarios that would result in something like that.
Points for the quick fix, though. It tells me Rigol is interested in catching and improving upon mistakes.
The following users thanked this post: kado
Online Sparky
Although this thread was the first focusing on RSA5000 -- or second if you count the much older thread (https://www.eevblog.com/forum/testgear/rigol-announces-phoenix-chipset-and-ultravision-ii-technology-platform/) -- there is (unfortunately) a lot of useless posts here.  Makes more sense to keep on-topic in Dave's new thread (https://www.eevblog.com/forum/testgear/new-rigol-real-time-spectrum-analyser/).
Agree
Technical Support
Offline IRB
Has anyone else tried a Rigol 5065-TG?
I had a demo unit, I did a SAVE "Screen Image", Rigol emailed me back that this is not a bug...   |O
The bmp files have a pop up on one, and on the other one a keyboard over the data, I converted them to jpg to post here
Now I found how to put up a Poll
https://www.eevblog.com/forum/beginners/rigol-5065-tg-save-image-function/new/#new
« Last Edit: June 19, 2018, 06:19:34 pm by IRB »
Offline nctnico
How the hell can they miss this? And why BMP as screendumps? This doesn't bode very well for the new Rigol DS7000 oscilloscope.
Offline IRB
The save image can be bmp jpg or png.
 There is also a Save Measurement for the 801 points of data across the Span.
Offline pascal_sweden
  • Country: no
I was wondering why there isn't a save option where you can only capture the actual graph?
The save is an actual screenshot. Fair enough.
But there should also be a save for the actual graph, as now you will have to cut it out from the graph manually when you put it in a formal report.
Offline IRB
Yes, true, but the data I need is behind the keyboard...
« Last Edit: June 19, 2018, 06:19:48 pm by IRB »
