OK, thanks for the replies putting me straight on "calibration".
Check the Cal points even just for DC. 5, 50, 500 and 600V. Resistance Cal needs a large spread too. If you upload someone elses Cal data and change 1 or 2 of the lower points you can reach you will screw with the Linearity of all future measurements.
If it forces you to go through all of those before pressing "voltage done" then it's going to be tough.
Chalk it up to experience I guess. We've all made expensive mistakes.
