Products => Test Equipment => Topic started by: adauphin on February 03, 2019, 05:11:00 am
I haven't spent much time with this scope, forgive me if I've overlooked something obvious.
The green bar on the lower 3rd of the display (Parallel ASC)....can you tell me how to turn it off.... 8)
Press Math, then Decode1, then change Decode to OFF
I did try that. If I turn decode on, I get another green bar below that one.
Daggone....lol, been a long day.
Was under decode 2... |O
All is good.
Ah yeah... I almost mentioned that, but glad you worked it out yourself. I couldn't quite read the flag to see if it was labelled B1 or B2.
Edit: It is just legible in the 2nd photo.
