Author Topic: How to enable Option AM in a Tektronix TLA7AC4?  (Read 522 times)
Offline calibrationfixtureTopic starter
« on: April 25, 2023, 09:45:25 am »
Hi to All,
I used; SYST:CONF:OPT AM. Comparable with what to be used for a TLA7PG2 (in that case;  SYST:CONF:OPT OPT1M). With this I got Extension: AMux BASIC and Analog Outputs Disabled. Option AM (AMux FULL) is still a possible Upgrade in TLA Powerflex Utility. Used also:
SYST:CONF:OPT AMFULL
SYST:CONF:OPT OPTAM
SYST:CONF:OPT OPTAMFULL
as scripts. AMux FULL is still a possible Upgrade. Anybody?
Calibrationfixture
« Last Edit: April 25, 2023, 10:09:29 am by calibrationfixture »
Offline nctnico
Re: How to enable Option AM in a Tektronix TLA7AC4?
« Reply #1 on: April 25, 2023, 09:59:53 am »
Hi to All,
I used; SYST:CONF:OPT AM. Comparable with what to be used for a TLA7PG2 (in that case;  SYST:CONF:OPT OPT1M). With this I got Extension: AMux BASIC and Analog Outputs Disabled. Option AM (AMux FULL) is still a possible Upgrade in TLA Powerflux Utility. Used also:
SYST:CONF:OPT OPTAM
Calibrationfixture
Load the Powerflex utility exe file in a hex editor and look/search for the option strings. You'll find the correct option name for sure.
