Author Topic: SR560 — Low-noise voltage preamplifier - Schematics  (Read 2859 times)
Offline branadicTopic starter
  • Sounds like noise
« on: April 17, 2020, 06:53:29 pm »
does someone has the schematics of Stanford Research SR560 Low-noise voltage preamplifier? Unfortunately they are missing in the manual available on the web. I appreciate any help, thanks.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline DaJMasta
    • medpants.com
Re: SR560 — Low-noise voltage preamplifier - Schematics
« Reply #1 on: April 17, 2020, 07:01:59 pm »
My guess would be intentionally omitted rather than missing, but the board is double sided and the full BOM is included in the manual along with a block diagram (or at least a description, don't remember offhand), so it shouldn't be hard to reverse engineer/trace out if you need only a portion of it.
  • Sounds like noise
« Reply #2 on: April 17, 2020, 07:37:58 pm »
Was already helped and pointed to a version, that includes schematics, thanks.
https://doc.xdevs.com/docs/Standford%20Research%20Systems/SR560/Stanford_Research_SR560.pdf
-branadic-
The following users thanked this post: egonotto, thm_w, MegaVolt
Offline jfphp
« Reply #3 on: March 09, 2021, 03:25:53 pm »
I am in the same research : unfortunately your link doen't drive to a manual with the schematics
Offline SilverSolder
« Reply #4 on: March 09, 2021, 06:15:18 pm »
What do you call the scribbles that begin on Page 15 if not schematics?
Offline jfphp
« Reply #5 on: June 23, 2021, 02:50:48 pm »
Impossible to use this link : security warning !
NET::ERR_CERT_DATE_INVALID
Offline Chris56000
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
The following users thanked this post: egonotto, 2N3055, syau
