Author Topic: How to let out the magic smoke in a UT61E  (Read 2987 times)
Offline Lightages
  • Canadian po
« on: May 04, 2013, 09:24:02 am »
Some here might know that I fried my UT61E by trying to jam 2500 volts down its throat. It didn't like it and we are no longer friends. Well that's what you get when you push things to far.
http://youtu.be/hhBbvIf3E0s
Online SeanB
Re: How to let out the magic smoke in a UT61E
« Reply #1 on: May 04, 2013, 10:01:13 am »
Looks like i might just take a old set of phone line spark gaps and install them in mine......... I have plenty of them around, from dead fax machines that died from lightning hitting them. The spark gaps worked, but the power supplies never survive having the copper blown off them.
Offline KedasProbe
« Reply #2 on: May 04, 2013, 04:01:50 pm »
I first thought why is there such a big difference between the setting and the measured value.
Looked up your device and I saw that your device has an accuracy between 0 and +20% so +10% voltage is normal.
Nice to see the brymen handles it correctly although I don't expect to measure any such high voltages.
« Last Edit: May 04, 2013, 04:51:59 pm by KedasProbe »
Not everything that counts can be measured. Not everything that can be measured counts.
[W. Bruce Cameron]
