Author Topic: SCPI protocol to GUI  (Read 1088 times)
Offline AndbroTopic starter
« on: April 01, 2020, 05:41:07 pm »
Hello,
I bought a Chinese benchtop multimeter. There is no PC software available. However, the driver and the SCPI protocol are available. Is there any software with which I could do a GUI?
Thank you
Offline skander36
Re: SCPI protocol to GUI
« Reply #1 on: April 01, 2020, 06:41:09 pm »
I think you could use NI LabVIEW .
But virtually any programing or scripting language cand be used.
Qt and Python scripts are used frequently .
Offline thm_w
  • Non-expert
« Reply #2 on: April 01, 2020, 10:17:47 pm »
Here is an example timber23 made for the DG800 signal gen with the qt/python mentioned: https://www.eevblog.com/forum/testgear/new-rigol-16-bit-function-generators-dg800900-series/msg2425551/#msg2425551
Design is not quite as straightforward as say visual studio C#, but there are tradeoffs, can try them both.
