I’m new to logic analyzers. I have an Agilent 1683AD. I need to know how to use it safely without damaging the equipment. Can you guys point me out how not to destroy it and what are the good practices to use it effectively ?
Any beginner tutorials you have or you have found would be certainly helpful for me to get started.
Treat it as an
unisolated "USB oscilloscope" that doesn't record analogue waveforms but does record digital signals.
Don't exceed the input voltages specified in the manual. They will be much more restricted than an oscilloscope's input.
Do connect all the common "0V" wires to the same point; that is unlikely to be difficult, but I have come across equipment with TTL signals running between -16V and -11V!
As with oscilloscopes, only attach the 0V to points on the circuit that can be connected to protective mains earth.
Consider using a scope to verify that the points that you intend to use for connections actually are "safe" before connecting the LA.
As for a tutorial, RTFM is always a good start
