I bought that multimeter around 1990 and I never learned how to read the bar... According to the manual, "the 41-points bar displays in proportion to digital value". But I can't help you right now, because I need to fix mine
It stopped working after I measured a resistor connected to a capacitor that was still charged... Big mistake
The LCD display works but the readings are completely incorrect, changing randomly even when the probes are disconnected. Exactly like this icon... just imagine an LCD in place of the VU meter
After I downloaded the diagram I checked the input section: diodes and resistors were OK, so I focused on the AD converter. I removed it and turned on the multimeter, but the readings were identical. But I guess it doesn't mean it's working, right? I'm quite confused...
I'm gonna check if ICL7106 is socketed or not. Any suggestion will be much appreciated. Thanks in advance, and please forgive my clumsy english.
