Hi
I have a need for pre-compliance testing of a product I am developing. I plan to purchase a Siglent 3000 series Spec An. Of course by itself, it is useless for EMC testing without the sensors and accessories needed to measure stuff. One of those thing I will need is a decent bi-conic antenna. The commercial ones seem to be priced in gold.
I can design and build an antenna but the problem is then to calibrate it to a reasonable degree of accuracy for pre-compliance testing. One procedure is to use a calibrated antenna as a signal source to test and calibrate the antenna under test (AUT). But that requires one of those golden calibrated antennas.
I propose to overcome the need for a golden calibrated antenna by building and testing two identical, but unknown antennae. The idea is simple (which probably means others have already thought of it and done it).
Step 1. Design/Build two identical antenna.
Step 2. Connect cables / attenuators etc to the Spec An.
Step 3. Normalise the test rig by doing a sweep with the antennae replaced with a short coax link.
Step 4. Insert antennae and do the tests.
Step 5. Halve the test results.
This is illustrated in the attached drawing.
The attenuators would provide wide band 50ohm closely matched to the Spec An impedance to miminise resonance in the test rig.
The antennae would need to be mounted far enough apart to be in the far field.
The test location would need to be rf quiet and without reflections.
The null link between the attenuaters would need to be as short as possible (an adapter).
Both legs of the test rig (Tx and Rx sides) should be identical for all sorts of reasons.
So the test results would then simply need to be halved to get calibrated performance.
If each antenna had 5dB gain, the test curve would show 10dB.
If each antenna had a 20db loss, the test curve would show 40dB.
So by halving the figures measured by the Spec An, a calibration curve would be produced.
The method can be checked at a single frequency by using two identical dipoles whose performance can be mathematically calculated. A ring-in for a golden calibrated antenna.
So the outcome of testing two identical but unknown antennae would be a known calibration curve. In addition, there would be a spare antenna with its own calibration curve.
Some might think that building 2 antenna when you only need one is a waste. Building 2 antenna is not much more work than building one when time taken to design, buy parts and test are accounted for. The 2nd antenna could then be sold or kept as a spare.
I would be interested to know if anyone else has tried this and if so, what were the results?
Dazz
