Author Topic: Siglent SDS1102CML alternative firmware  (Read 2504 times)
Offline diodakTopic starter
« on: January 24, 2015, 03:44:27 pm »
SDS1102CML with firmware from LeCroy (Waveace 1012 - waveace1xxx_5.01.02.27) works ok. However, you need a cfg file. CFG from Siglent is 337,336 bytes. Of which 336,960B (480 * 234 * 3) is the boot logo (negative bmp). The remaining 376 bytes are some configuration and model name. Does anyone have a Lecroy cfg file?
