It took a hit on the right front corner, as viewed from the front. Fortunately it was wrapped in a plastic sheet, so I was able to capture most of the pieces, at least those big enough to see. It's not really terrible, I'm going to make an attempt to fuse the larger pieces together with plastic-melting solvent as a first try, then fill in the small gaps with epoxy. Pretty odd, and lucky, there is no sheet metal damage at all. Would you happen to know anything about the internals of this beast? I'm reluctant to open it up until I deal with the fractured plastic, it be easily made worse I think.
Thanks,
Bill
ps: looks like all the 166x machines use the same enclosure & trim, perhaps there is a dead parts machine somewhere that might have intact trim?
