Author Topic: Plus/minus sign on clamp meter jaw  (Read 3452 times)
Offline bitwelderTopic starter
« on: July 01, 2015, 05:30:06 pm »
The other day I received my latest equipment purchase, a mini-clamp meter UT210E, which has been described on this thread: https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/msg560006/#msg560006
On the left clamp 'jaw' there is a plus sign on the top side, and a minus sign on the bottom side. See e.g.
What's its purpose?
Offline dom0
Re: Plus/minus sign on clamp meter jaw
« Reply #1 on: July 01, 2015, 06:25:59 pm »
Nominal direction of current.
Offline belasajgo
« Reply #2 on: July 01, 2015, 06:29:12 pm »
It has to do with DC current measurement and the direction of the flow of current in the wire (polarity of the magnetic field). If the flow of current is in the other direction, you will get a negative value.
Offline Fungus
« Reply #3 on: July 01, 2015, 06:34:01 pm »
What's its purpose?
So you can tell which way the electrons are flowing.
(If the meter shows a negative number then they're going the opposite way to the markings on the clamp)
« Reply #4 on: July 01, 2015, 10:22:48 pm »
Thanks!
Offline jeroen79
« Reply #5 on: July 01, 2015, 10:41:43 pm »
And the + means current coming out of the clamp?
(and electrons going in)
« Reply #6 on: July 02, 2015, 06:01:11 am »
Simple test: test lead going from the + terminal on the bench PSU into the clamp from the top (+) side, to a small load and return to the - terminal on the PSU => meter measures positive current
Insert + wire from the bottom of the clamp => meter measures negative current
Offline Fungus
« Reply #7 on: July 02, 2015, 07:54:40 am »
Good question! And an amazing opportunity to do an experiment!! I wouldn't let this one escape if I were you...
https://xkcd.com/567/
« Last Edit: July 02, 2015, 08:38:18 am by Fungus »
