I reckon that I was spot on about that scope being 120V configured because I see that the seller has changed his wording
to read as
"Tested earlier in the day and it turned on, showing line, however when tested just now, would not turn on. Also slightly taped at side as case has seen better days!
Comes with 2 pin (US) power cable," notice the change from 2 pin Euro to 2 pin (US)?
If that is true, just how much internal damage has been done do you think. would any of the circuit boards and electronics survive being served twice their normal voltage? I suppose thinking about it, the damage might be contained to the voltage regulators and possibly the transformer?
At least he did change the warranty to include a 14 day refund in case I did discover anything that I was not expecting?
Whatever he has done with it, it can't have damaged the parts that I'm currently primarily interested in
