Author Topic: Tek465 question  (Read 887 times)
Offline andy3055Topic starter
Tek465 question
« on: March 29, 2020, 01:23:17 am »
Can someone please give me some ideas on the 465 as below?
Attaching pages from the Tek 465 manual that shows the high voltage section of this scope and the parts list. What would be the reason to have some of the caps in this part of the circuit rated at 6kv, 4kv etc? The diagram shows TP 1423 at -2450 volts and I was trying to figure out how they came up with those values. Is it possible that there will be a surge of some sort at a given time?
For ex: C1487  .0047/6kv and C1488  .0012/4kv
Any feedback is much appreciated.
Thanks.
Offline jxjbsd
  • Country: cn
  • 喜欢电子技术的网络工程师
Re: Tek465 question
« Reply #1 on: March 29, 2020, 09:43:01 am »
I think it's to reduce leakage
Last week, I just repaired the HV part of this equipment
Analog instruments can tell us what they know, digital instruments can tell us what they guess.
The following users thanked this post: andy3055
Re: Tek465 question
« Reply #2 on: March 29, 2020, 09:54:45 am »
The HV caps are part of the DC restorer circuitry and need to be HV rated with a sufficient derating for reliability.
Quite normal to have 4 or 6KV ratings where they are used.
Offline jxjbsd
  • Country: cn
  • 喜欢电子技术的网络工程师
Re: Tek465 question
« Reply #3 on: March 29, 2020, 10:00:08 am »
Lower voltage can prolong the service life of capacitor。465 brightness failure is often related to the leakage of these capacitors
Offline Shock
Re: Tek465 question
« Reply #4 on: March 29, 2020, 12:24:49 pm »
If you look at the schematic you can see they are connected to the tube.
Re: Tek465 question
« Reply #5 on: March 29, 2020, 04:21:25 pm »
Thank you to all. I did not think about the de-rating under high voltages. The replies are very much appreciated.
