After 5 or so minutes the screen goes blank, so I cut power. After 30 seconds I repeat the boot+test procedure, but it will not test. It simply says RS-232, along with the little error you see in the third photo. Too quick to photgraph. In the 3rd photo, you see the machine working (apparently correctly), but with the little "error" remaining.
OK, when it shows the "error" indicator on the display, I believe you can go into the system menu and review the error codes.
Press SHIFT then ENTER (MENU ON/OFF) to enter the menus.
Press right arrow three times to get to "SYS MENU", then down arrow once to enter that menu.
Press right arrow twice to get to "ERROR", and then down arrow to view the error list.
I think you can use left/right arrows to scroll through the errors if there are multiple.
Press SHIFT then ENTER to exit the menu system, or you can use up arrow to go back up to higher level menu, and continue looking at other options.
I'm pretty certain the "RS-232" message is not relevant to your problem, as that is a normal message at startup if RS-232 is enabled. Not saying there isn't a fault with the RS-232 port, or the related settings.
