Author Topic: Rigol DS1054Z, DS1074Z or DS1104Z to bump up to 100MHz  (Read 3815 times)
Offline 366Cobra
« on: December 07, 2014, 10:03:23 pm »
Hi All,
I am wanting to buy a Rigol 4 channel scope - am a hobbyist.
Have been reading a lot about Rigol DS1054Z, DS1074Z and DS1104Z and bumping the first two up to 100MHz.
What I have not been able to find is, if the hardware in all of them is the same and that the software selects the MHz.
Since budget is an issue, can I get a DS1054Z and bump it up to a DS1104Z?
Or would it make more sense to get a DS1074Z and bump it up to a DS1104Z
At the moment I do not need 100MHz, but I like things to be future proof.
Any input is appreciated.
Thanks
Martin
Offline hammy
Re: Rigol DS1054Z, DS1074Z or DS1104Z to bump up to 100MHz
« Reply #1 on: December 07, 2014, 10:34:32 pm »
Hi Martin.
Unfortunately you are asking some questions who are already discussed over and over again. ,-)
Please use the search function and have a look ...
The short answer is: Yes, it is the same hardware. Yes, it is possible. Yes, it is your own decision.
Offline 366Cobra
« Reply #2 on: December 08, 2014, 11:07:14 pm »
thanks for the answer, that made it easy.
Sorry, but I was searching Google and in here for two days and could not find your answer.
@hammy
Besten Dank
Offline hammy
« Reply #3 on: December 11, 2014, 12:18:28 pm »
@hammy
Besten Dank
Kein Problem. Viel SpaƟ mit dem Oszi!  ;)
