Author Topic: HP 8903B which manual to use  (Read 1547 times)
Offline Gmanfro
« on: June 13, 2016, 11:29:36 pm »
Just bought a HP 8903B distortion analyzer serial # 3413A, not sure which manual to use to operate it or do I use both? Seems like the last update stopped at 2450A-2948A and there was a prior one. Seems like there is also a cal manual. This one was just recently calibrated, but want to print a operation manual so I know how to use it properly. Any help on operation or proper manual will be much appreciated.
Online macboy
Re: HP 8903B which manual to use
« Reply #1 on: June 14, 2016, 12:59:33 pm »
The service manual is in two volumes, you need both. There is also an operation/calibration manual. My op/cal manual indicates S/N range 2450A to 2922A. I downloaded these from Agilent directly, and I don't know of a source of better quality or later manuals.
Offline Gmanfro
« Reply #2 on: June 15, 2016, 11:47:27 am »
Thanks,  Got the op/cal manual and there is 2 service manuals. Looks like I have them located from Agilent. So 3 manuals in total. Guess my brain was overloaded the other day and just got confused. Thanks for straightening things out.
