Author Topic: ANN HpW-Works Version 3.5.0  (Read 1098 times)
Offline hpwTopic starter
« on: May 16, 2016, 09:55:05 am »
HpW Works is a software based (audio) signal measurement system for the MS Windows platform.
The software analyzes a device under test (DUT) using a sound card, wave files and text (ASCII)
files. Various signal analysis are performed such as RMS, DR, THD, THD+N and more. The
latest version includes Real Time FFT. The built in Wave Generator software supports
various signals like, DC, sine, sine & harmonics, multi-sine, noise, jitter test signals, etc.
Also, the user can select individual sound card input and output and each with different
sample rate and bit depth. Supported driver formats are MME, WDM, ASIO Synchron I/O,
ASIO Multi-Client and WASAPI exclusive mode.
The new release includes an improved lookout towards MS Windows 10, seamless operation,
several new display options, delivers higher speed and precision measurement.
* Test Benches:
o FFT 2D (Level Spectrum)
o PSP 2D (Power Spectrum)
o PSD 2D (Power Density)
o FFR 2D (Fast Frequency Response)
Detailed specification on the given PDF file or the free Evaluation SW.
mailto:support@hpw-works.com
http://www.hpw-works.com
