Hi
I would also be interested in this information.
I opened my jbc CD-Station today and found out, that inside is an analog devices adm3251e RS232-isolator.
The pinout is the same as for their RJ12 robot communication port:
Pin 1 and 6 are NC, 2 and 5 are GND, Pin 3 is Tx and 4 is Rx
The communciation is RS232 with 8 data bits, 1 stop bit, odd parity, LSB first and it seems to be 250K baud.
The soldering station only sends a periodic signal at 20ms intervals and it is always the same, removing the tool from the stand does not change it.
The message seems to be:
HEX: 0x10, 0x02, 0x10, 0x10, 0x11, 0xFD, 0x00, 0x01, 0x11, 0xED, 0x10, 0x03
ASCII: DLE, STX, DLE, DLE, DC1, ý, NUL, SOH, DC1, í, DLE, ETX
The STX and ETX are similar to their robot communication stuff, not sure what the rest is.
So we would need someone who has access to a jbc fume extractor and a CD soldering station and sniff the communication between the two.
As the fume extractor most likely needs to send a message to receive the tool status.
