Author Topic: HP 5334A service manual?  (Read 2246 times)
Offline usuthu65Topic starter
« on: October 25, 2019, 01:31:03 am »
Hi all,
Trying to find an online copy of the HP 5334A universal counter service manual.  I can find the 5334B but not the -A.  The goal is to see whether it is possible to field install the better OCXO (Option 010 originally; 10811A oscillator) into a 5334A that does not have it already, and what that would require.  The main board clearly has a multipin connector and an outline where the Option 010 goes, but I don't know more than that.  Perhaps the idea is a non-starter..  Searched the web and here to no avail.
Thanks in advance.
Offline 0culus
Re: HP 5334A service manual?
« Reply #1 on: October 25, 2019, 01:39:15 am »
Artek has it: http://artekmanuals.com/manuals/hp-manuals/
It will cost $10 to get the operating manual and service manual together, but it's worth it because their scans are way better than the free junk (even from Keysight) and OCRed to be searchable.
« Last Edit: October 25, 2019, 01:40:47 am by 0culus »
Offline ekoloski
« Reply #2 on: March 24, 2023, 12:57:29 am »
I am a little late to the party on this one, but I'll reply back in hopes that it helps someone out. Yes, you can field install this option, the steps outlined in the manual for the 5334B work just fine.
It's been a while, and I'll need to dig through some old project files for the details. What I do remember is that you need to unsolder and move C8 to C100. I also built a small board to mount the ocxo, provide 12v and add support for electronic frequency control. I then took a panel mount 10-turn potentiometer and stuck it through the back so the unit can be calibrated without opening the case. Finishing touch is a small panel mount LED on the front panel at the top right which indicates that the oven is still warming up and measurements should not be trusted.
If you are still looking to do this mod, let me know. I'll post the project files.
« Last Edit: March 24, 2023, 02:05:13 am by ekoloski »
