Products => Test Equipment => Topic started by: SeoulBigChris on August 01, 2021, 08:27:22 am
I'm embarrassed to ask this, but I can't find it in a quick scan through the manual. If I get one of the HP-5384A frequency counter, or a similar one from that era, Can it be put in a simple counter-only mode? You know, just to count events. I could swear that I used this functionality back in my younger years, but I could be recalling a another brand or model.
5384A can’t count events unfortunately, only do frequency and period measurements. You will need another counter for that.
I’ve found a cousin, the 5316A which is classified as a universal counter.
Yes that’d do the job. Those are quite nice counters. If you want the best of both worlds and some more then the 5334B is a good one to look out for too.
The 5334B can be retrofitted with an OCXO module and 1.3GHz option cheaply. I’ve done both of those before.
Out of curiosity, what differentiates a universal counter from a frequency counter? It seems to be that adding the ability to tally events / totalizing function to a frequency counter is merely a matter of firmware to display the data in a different manner. You’re already thresholding pulses, counting pulses, and have a gate — I don’t see that additional circuitry would be needed.
What would be an equivalent universal counter from the 34401A DMM era, if you happen to know off the top of your head ?
Simple frequency counters are just that—only measure frequency with a discrete set of counting times.
Universal counters add capabilities for period, period averaging, totalizing (count ch A while ch B is high), frequency ratio (A/B), sometimes computing frequency from reciprocal of measured period, etc. Back in the day, this (except for reciprocal frequency) was done in hardware.
Regarding counter from 34401A era you’d be looking for the 53131A. Like the 34401A they still command serious money though, especially with channel 3 and OCXO options.
Also like the 34401A’s the VFDs are a bit hit and miss now.
Tim, yeah, I get that. I guess my question was more coming from the point of view of the HP 5384A that I originally posted about. This seems to have a lot of the "advanced" functionality you describe, and I was just surprised that a simple totalizing mode wasn't available.
Different price points--not everyone needed totalize mode.
Well, wish me luck. Got a used HP-5384A for about $200 on the way. Should arrive in a couple days.
