Author Topic: HP 5386A frequency counter teardown  (Read 9009 times)
Offline remageFrsTopic starter
« on: March 14, 2016, 12:44:13 am »
Hi!
First post here, so I thought it'd be a good idea to take some inside photos of an HP 5386A frequency counter I scored recently on eBay.
Also, I'm curious if anyone here has a similar counter with the "Option 004" OCXO timebase?
Higher resolution images are here: HP 5386A
Most of the ICs/caps have a late-'87 datecode, the TCXO has '8802' stamped on its side (but I'm not 100% sure that's a datecode), so I think it's an early '88 unit. Despite the age, the whole instrument looks really nice and clean.
I didn't have the confidence to open up the RF shield on the 3 GHz frontend, sorry... :)
Edit: Found the service manual on Keysight's homepage.
It mentions on page 2-4 that the standard oscillator can be replaced by the "Option 004"  OCXO. The HP number is 0960-0636, I couldn't find any further info about it. Does anyone have an idea if a modern ovenized oscillator can be installed there?
« Last Edit: December 14, 2021, 04:37:43 pm by remageFrs »
The following users thanked this post: Exeter
Offline deepskyridge
Re: HP 5386A frequency counter teardown
« Reply #1 on: March 17, 2016, 11:26:18 pm »
I have one just like it except mine has the OPT-004 installed. Nice counter, mine works fine.
Gary
Offline picburner
« Reply #2 on: March 18, 2016, 04:58:54 am »
Nice instruments.
A guy in Poland has made an option 004 clone and sell it on ebay.
« Reply #3 on: March 28, 2016, 07:32:35 pm »
Found a NOS oven oscillator for the counter!
Offline corn11
« Reply #4 on: January 16, 2017, 05:57:11 pm »
I have a 5385a on which I also want to install the option.
May I ask where you've managed to get the original OCXO ?
I've wrote some obsolete part suppliers but none of them has responded so far  :-\
« Last Edit: January 16, 2017, 05:58:57 pm by corn11 »
Offline corn11
« Reply #5 on: January 24, 2017, 07:10:19 pm »
I think I've found the OEM of the OCXO: Isotemp Research Inc. .
They (presumably) sell the matching OCXO on eBay:
eBay auction: #171831243622
The given datasheet values correspond to the ones in the datasheet of the 5384A/85A/86A also the pinout and the shape, which aren't really common match.
It would be a really strange coincidence if this isn't the OEM part ;)
I've recently ordered one and it should arrive this week.
« Last Edit: January 24, 2017, 07:12:00 pm by corn11 »
Offline calin
« Reply #6 on: January 24, 2017, 08:20:06 pm »
I have one too, no OCXO .. got it for 20$  :-+ .. With the spare money I got an UBLOX and a Morion OCXO and a couple of chips and I am almost done getting a half a$$, good enough for my needs GPSDO.
One thing that wold be a nice hack will be to add a backlight to the lcd.
« Last Edit: January 24, 2017, 08:23:56 pm by calin »
Offline mmagin
« Reply #7 on: January 24, 2017, 08:31:14 pm »
I have the 1 GHz version of this (without OCXO) and I previously had the 225 MHz version (with OCXO).  Nice little counters, though in both situations I used the 10MHz reference from my GPSDO instead.  Interesting that HP put a third party OCXO in these instead of the 10811 -- presumably it was a lot cheaper.
Offline corn11
« Reply #8 on: January 24, 2017, 09:09:24 pm »
Building a GPSDO is also on my list. I've already bought a Navman-GPS-module and a Trimble OCXO but had no time to get the thing together.
So for now hopefully the OCXO option will do the business ;)
yeah, a backlight hack would be really nice indeed :) I belief someone on the forum has already done this with a 3478A DMM.
The following users thanked this post: Miti
Online Miti
« Reply #9 on: December 14, 2018, 03:05:40 pm »
https://www.eevblog.com/forum/testgear/hp3478a-backlight-my-version/msg1507039/#msg1507039
Fear does not stop death, it stops life.
Offline 0culus
« Reply #10 on: December 15, 2018, 06:30:03 am »
Really nice and clean too! Good catch!  :-+
I have a 5335A with the OXCO option (and I think pretty much every other option as well; even the DC voltmeter option) that sits on top of my 5350B microwave counter, and provides the timebase for it. I recently also replaced my shitty Chinese DDS with a 3325B from the same seller I got the counters from, which also has an OCXO, but it doesn't have an internal connection to it, so I have a jumper.
Offline Jwalling
  • This is work?
« Reply #11 on: December 15, 2018, 12:29:18 pm »
Seeing as how this is a teardown thread, here's some pictures of the 3GHz prescaler.
Jay
System error. Strike any user to continue.
The following users thanked this post: corn11
Offline rhb
« Reply #12 on: December 16, 2018, 12:08:06 am »
Curiously, all my HP gear has the OXCO option except my Keysight 33622A.  But I plan to connect everything to a GPSDO, so I don't think it matters much.  Even without the OXCO the 33622A is very stable.  But I haven't put together a test and verification plan for my bench yet.
Offline Radiorandy
« Reply #13 on: February 28, 2019, 08:07:21 am »
I've been trying to find the guy in Poland that has the Option 4 clone OXCO. Doesn't show up on Ebay. Anyone have a link or contact info?
Thanks
Randy
Offline wkb
« Reply #14 on: April 26, 2023, 07:36:53 am »
Page 63 shows a picture of one of the GaAs chips used on the hybrid.
http://roryvantuyl.com/PDFs/The%20Early%20Days%20of%20GaAs%20ICs.pdf
Wilko
