Author Topic: HP 5340A Frequency counter.  (Read 4475 times)
Offline neoTopic starter
  • The specialist.
« on: June 29, 2017, 01:25:52 am »
I am hoping someone could help me. I have my eye on a HP 5340A frequency counter, besides the higher frequency limit does it have anything to offer over my current frequency counter? My current is Bel Merit fc-200 and it displays 10.0 hertz as .0100 KHZ. The primary question being will the HP offer any higher of a resolution for low frequency signals?
« Last Edit: June 29, 2017, 03:55:13 pm by neo »
Offline alm
Re: HP 5430A Frequency counter.
« Reply #1 on: June 29, 2017, 02:58:32 pm »
Are you sure that model number is correct?
To figure that out, try comparing the datasheet / catalog pages for both counters and look for specifications or features that are important to you. They will usually give figures like accuracy and resolution. For low frequency resolution without ridiculous gate times you want a reciprocal counter.
This application note may be helpful: HP AN 200-4: Understanding Frequency Counter Specifications.
  • The specialist.
« Reply #2 on: June 29, 2017, 03:56:06 pm »
Sorry my brain mixed the number up it does that sometimes, i fixed it.
Offline TheSteve
  • Living the Dream
Re: HP 5340A Frequency counter.
« Reply #3 on: June 29, 2017, 04:06:21 pm »
The 5340A displays frequency down to the Hz. If you're looking for something into the milli Hz or micro Hz you could look for a 53131A or 53132A(depending on budget).
VE7FM
  • The specialist.
« Reply #4 on: June 29, 2017, 04:32:24 pm »
The question is not, how low does it go, so much as, what is the resolution of that counter when measuring 10 hz.
Offline TheSteve
  • Living the Dream
« Reply #5 on: June 29, 2017, 05:50:31 pm »
Sorry I wasn't very clear - I was referring to the resolution not the lowest possible frequency it can measure. I don't think the 5340 will offer you any improvement but can fire mine up if needed. The Nixie tube version is pretty sweet to watch.
VE7FM
The following users thanked this post: neo
  • The specialist.
« Reply #6 on: June 29, 2017, 06:29:57 pm »
Thank you thats very helpful. The original problem which required higher resolution has since been solved though i still want one.
« Last Edit: June 29, 2017, 06:32:20 pm by neo »
  • The specialist.
« Reply #7 on: June 30, 2017, 03:54:36 am »
Well i just bit the nearly literal bullet and spent 150 bucks on a nixie tube version of the HP 5340A, with what appears to be every bell and whistler AND a 6 month warranty.
I wonder what besides food is edible... (joking)
Offline TheSteve
  • Living the Dream
« Reply #8 on: June 30, 2017, 04:51:03 am »
Just had a quick play with mine - it works fine down to 2 Hz and displays 10 Hz properly:
VE7FM
  • The specialist.
« Reply #9 on: June 30, 2017, 06:23:41 am »
Just out of curiosity, short of setting up an entirely vintage lab of old HP stuff does the digital input/output serve much purpose anymore?
  • The specialist.
« Reply #10 on: June 30, 2017, 06:34:42 am »
Some pictures off of ebay of the one i got.
