Finally found free time, so how is it going? Not good. I removed C16A, 13, 14 and 20. T1 tapse open at 7 and 10--fuse blows on mains, fine on dim bulb tester. Removed Q4,6,7-fuse good on tester and mains. Put Q7 in-fuse blows on mains, good on tester. Removed Q7 and put in Q6, fuse good on tester and mains. Left Q6 in and put Q4 in-fuse blows on mains and stays on with tester. Removed Q4 and put in C14 -fuse blows on mains, good on tester. While the caps were out, I tested C16A, 14, 13 and 20 with the following:
C13-490uF--529uF, D= .036, ESR 0, Q= 27.4, theta= -87.9
C14-490uF--540uF, D= .033, ESR 0, Q= 30.1, theta= -79.8
C20-80uF--91.6uF, D.112, ESR .2R, Q=8.89, theta= -83.5
C16A-.05uF--45.7 nF, D= .024 ESR=1.1M, theta -88.3
The caps were checked with my DER EE D5000
The additional problem I am running into now, by swapping components in and out, I am starting to lift pads. I am beginning to wonder is this should go to the to be stripped shelf. The next thing I am going to try is to lift the cathods on CR28 and reattach pin 7 and 10 on T1 and see what happens. If the fuse stays good, I'm thinking that the next step would be to reattach CR28 and 29 and lift the anodes on CR26 and 27 and seea if the fuse blows. I will just leave C14 in while I do this because, as I said, I am starting to lift pads and I am not quite ready to scrap this. I will update further. Any additional comments/suggestions would be appreciated.
