Author Topic: Hantek 6254BD 250MHz 1GSa/s PC/USB DSO  (Read 26815 times)
Offline dedcaps1
Re: Hantek 6254BD 250MHz 1GSa/s PC/USB DSO
« Reply #50 on: August 27, 2024, 12:28:30 pm »
hi
does anyone know something about the Be automotive version?
i have a very similar "signal" like this "without problem" picture:
https://www.eevblog.com/forum/testgear/hantek-6254bd-250mhz-1gsas-pcusb-dso/msg2763860/#msg2763860
but even that "signal" is somehow really fuzzy and it is kinda hard to see any crank/camshaft signal and yet alone somehow compare them etc... and is there any better software for it, because even the trigger function doesnt seem to work and only "pause/stop" gives that really fuzzy graph... or is it just some signal interference on the car, because i have only tested it on a kinda old car...
i would basically expect the signal to be more clear and solid like this:
https://www.eevblog.com/forum/testgear/hantek-6254bd-250mhz-1gsas-pcusb-dso/msg2734660/#msg2734660
« Last Edit: August 27, 2024, 12:32:04 pm by dedcaps1 »
Offline radeko
« Reply #51 on: September 20, 2024, 10:00:08 pm »
You can use Hscope App with Hantek 6xx4 Osciloscopes.
It Works on Android. Can also work on android on raspbery pi.
Hscope Automotive Module: supported up to 125KSa/s real-time
https://www.martinloren.com/hantek-6xx4/
