I've just picked up an HP 66319D, whcih seems to be in rather good condition. It powers up, and the display is still very bright and clear.
However, the connector plugs for the outputs and the DVM are missing. What is the original manufacturer, pitch (5mm oder 5.08mm?), and part number?
On the Top of the unit there is a sticker "Open Sense Lead Detection is Disabled" and two additional lines that got unreadable.
Is this anything to worry? DO the sense lines still work, but there is no warning? How can I re-enable this?
Thanks.
Frank
