Author Topic: HP 6673A Terminal Block Size  (Read 896 times)
Offline pmendiukTopic starter
« on: October 14, 2022, 09:01:14 pm »
Hey all,
Does anyone know the size or part number for the removal terminal plugs for the HP6673A power supply rear analog and digital connectors?
Re: HP 6673A Terminal Block Size
« Reply #1 on: October 15, 2022, 01:51:24 am »
Wow nobody with any HP gear with a rear terminal block?  I bought the Power Supply and hoped I could get some terminal blocks before it arrived.
« Reply #2 on: October 16, 2022, 09:56:34 am »
Any pics?
Not sure about that particular model but my Agilent and HP system psu's use Phoenix Contact connectors. You need to take care to choose the correct pitch, as there's both 5mm and 5.08mm, and they aren't interchangeable.
« Reply #4 on: October 18, 2022, 06:00:18 pm »
Yeah, that's a Phoenix Contact style. You'll need to measure the pitch though, or buy one of each!
5mm pitch
5.08mm pitch
As you can see they look identical to the naked eye.
Good luck getting it working, that's a real beast of a PSU.
« Reply #5 on: October 18, 2022, 10:11:00 pm »
The power supply is due to be delivered tomorrow so I'll wait and measure the pitch of the connectors.  It's quite a lab power supply, there are no wimpy connectors, the output terminals are 1 inch copper bus bars.  Hopefully everything checks out OK and it just needs a calibration which I hope to do myself.
