TimFox said everything I was going to say.
On a multimeter, high input impedance is only available as long as the input voltage is within the input range of the high impedance input buffer, which is typically +/-10 volts maximum, but some extend to +/-15 or +/-20 volts. Above this, a resistive input divider is needed which limits the input resistance.
Electrometers which support a high input resistance at high voltages bootstrap their high impedance input buffer so that the supply voltage of the high impedance input buffer follows the input voltage, and then the high impedance input buffer drives the high voltage resistive divider.
