Author Topic: HP 8114A  (Read 241 times)
Offline ttbelectronics
HP 8114A
« on: September 22, 2020, 10:22:17 pm »
I have a Power Supply used on HP 8114A Pulse Generator and someone took man parts out, I got the unit running but still some voltages only half the value.
I believe 2 Zener Diodes are wrong part numbers.
Can someone have in hands the part number for VR501 and VR509?
Thank you.
Online 0culus
Re: HP 8114A
« Reply #1 on: September 22, 2020, 10:26:14 pm »
I'm sure the manual for this is available scanned online. Have you checked Keysight or BAMA (boat anchor manual archive)?
Re: HP 8114A
« Reply #2 on: September 22, 2020, 10:34:51 pm »
Yes I have the Manual but not part list.
Will need actually someone look the Power Supply and get the number direct from the part.
Online 0culus
Re: HP 8114A
« Reply #3 on: September 23, 2020, 01:59:29 am »
I see now...this is one of the newer boxes from the 1990s when service manuals started to not be released. Good luck, hopefully someone has one they can look inside for you.
The following users thanked this post: ttbelectronics
Re: HP 8114A
« Reply #4 on: September 23, 2020, 02:03:43 am »
Thank you.
