Author Topic: Hp 8563A SA  (Read 1857 times)
Offline jlmoonTopic starter
  • If you fail the first time, keep trying!
Hp 8563A SA
« on: April 22, 2014, 02:02:31 pm »
Well spring has sprung and it is annual time to check those nvram / backup batteries.
Does anyone know if a 8563A has a Dallas style or similar NVRAM or cal constant battery that should be changed.  Figured while doing my spring cleaning and equipment evals I would get all the batteries up to date.   Thank you in advance..
JLM
Recharged Volt-Nut
