Author Topic: HP 8590A SA: Requesting opinions  (Read 683 times)
Offline BillyOTopic starter
« on: June 07, 2023, 01:59:49 am »
Are these decent instruments?
I can get one tested and working with option 021 (HPIB) for $400 USD.  Is it worth that much?
Offline ps
Re: HP 8590A SA: Requesting opinions
« Reply #1 on: June 07, 2023, 06:41:23 pm »
Better get yourself an 8591A. Its time base is linked to a crystal oscillator (or an external 10 MHz reference). The center frequency of the 8590A drifts, it comes from an analog VCO.
The following users thanked this post: BillyO
« Reply #2 on: June 09, 2023, 02:29:51 am »
Thanks.
I wonder if it could be converted.
Update:
From the service manual:
"The First Local Oscillator Assembly is a yttrium-iron-garnet (YIG) tuned oscillator (YTO).  The YIG, a ferro-magnetic material, is polished into a small sphere precisely oriented in a magnetic field.  Changes in this magnetic field alter the frequency of the signal generated by the YTO.  Voltage control of the magnetic field surrounding the YIG sphere allows the analyzer to be swept or tuned within the frequency range of 2.05 to 3.55 GHz used in the first LO."
So I'm guessing a mod for a 10MHz reference input would not be possible.  Pretty cool technology though!
« Last Edit: June 09, 2023, 02:56:54 am by BillyO »
