Author Topic: HP 8654B 10-520 MHz Sig Gen light teardown  (Read 5184 times)
Online tautechTopic starter
« on: August 23, 2017, 12:09:50 am »
Couldn't find mention of one on the forum so it's appropriate I share some pics.
Front
Rear
Top
Note the SMA spanner screwed to the chassis for the rigid plumbing.
Top under PCB
Hinged PCB swung away.....still connected.
Inside rear
Bottom
What appears to be a cavity oscillator take a large amount of the space in the enclosure.
It appears fully functional.  ;D
Last Cal 2005.
This unit has option 003 installed....Reverse power protection. It's a small self contained module seen on the right of Bottom image.
All that was needed was some sticker residue cleaning and the frequency range knob grub screws tightened.
Manual:
www.ue.eti.pg.gda.pl/~bpa/lab_klb/pdfs/08654b_manual.pdf
18 Mb
Other than the MHz range selected there is no accurate display of the output frequency so a counter need be attached for accurate settings. There are/is some adjustment available for signal amplitude and user nulling for the moving coil meter.
A screenshot @ -3dB point of my SDS2304X. (~360 MHz)
« Last Edit: August 23, 2017, 12:21:05 am by tautech »
Avid Rabid Hobbyist
The following users thanked this post: Cubdriver, jonovid
Offline bjcuizon
  • RF and Analog Electronics Enthusiast
Re: HP 8654B 10-520 MHz Sig Gen light teardown
« Reply #1 on: August 23, 2017, 12:27:47 am »
Nice teardown and a great score! :-+
For the sma wrench, don't you need a proper torque wrench when putting the rigid cables back in..Or does it really matter much as its just SMA connectors? (and not the precision 3.5mm and all that sort of stuff)
Don't mess with an Electronics Engineer, it Megahertz!
« Reply #2 on: August 23, 2017, 12:33:09 am »
I don't think SMA was very common back in 1977 so rather than have techs grapple with them and pliers  :scared: it was just easier to add a wrench under a screw on the chassis.
Avid Rabid Hobbyist
The following users thanked this post: bjcuizon
Offline bjcuizon
« Reply #3 on: August 23, 2017, 12:52:12 am »
Hehe, it is assuming that the servicemen are the ones with the grey beards who just hold their tongue at a right angle and know when and where to stop turning the connector. ;) ;D
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #4 on: August 23, 2017, 03:08:05 am »
Cool deal. What's that component mounted at an angle (a pot or switch?). Is it due to some sort of gear arrangement?
Offline TheSteve
  • Living the Dream
« Reply #5 on: August 23, 2017, 05:01:20 am »
It looks like a beautiful unit - thank you for sharing. It might be time for a better camera though.
VE7FM
« Reply #6 on: August 23, 2017, 05:09:33 am »
It's the mode 3 position switch for the front panel meter. The switch itself is mounted inline with the shaft so only one shaft universal is needed. You can see the switch on the front panel to the left of the meter.
Avid Rabid Hobbyist
Offline hendorog
« Reply #7 on: August 23, 2017, 06:52:39 am »
That's a ripper, nice one Rob.
Regarding the images, no doubt he has shrunk them as I know he has a very restricted connection to the interwebs.
Offline TheSteve
  • Living the Dream
« Reply #8 on: August 23, 2017, 07:20:38 am »
Could be, it's a machine worthy of some nice hi-res shots, and looks to be in great shape.
VE7FM
« Reply #9 on: August 23, 2017, 07:59:53 am »
Rog is quite correct, they've been compressed from 5 Mb.
At some stage it's had a bump and one of the rear rails has a slight bend  and the pointer lug has been broken off the amplitude selector (visible in the pics) but neither affect functionality.  :phew:
Anyways, I'm very pleased with the HP Sig gen, other that my SA it's the highest frequency gear I have......as yet.
Avid Rabid Hobbyist
Offline wilgil
« Reply #10 on: September 22, 2017, 03:33:53 am »
You soooooo owe me now......
« Reply #11 on: September 22, 2017, 04:01:11 am »
:palm: I do.  :-*
Avid Rabid Hobbyist
