Author Topic: HP Agilent 53131A 53132A 53181A 12.4 GHz option  (Read 7109 times)
Offline VK4GHZTopic starter
« on: January 21, 2020, 12:44:22 am »
Hi all
I am looking at replacing my HP 5315A universal counter (with 1.3 GHz option) with either a 53131A or 53181A.
I'm leaning towards a 53181A because I don't need the extra measurement functions of the 53131A.
Just after a good basic counter that can work to 11 GHz.
And then again, there's the BG7TBL FA-2 counter that now goes to 12.4 GHz.
I'd have one of those already if it weren't for the tiny display and the pointless last four digits.
I'm impressed with the Cojotech HP/Agilent 531xxA prescalers, but only has 3 GHz and 8 GHz variants, and I find the "Channel 3 Guide" does not discuss the basic 225 MHz counters (ie; never fitted with any prescaler options) and any upper measurement limits that I believe can be coded into the U14 EPROM.
I notice that BG7TBL are now producing 12.4 GHZ prescalers for the 531xxA counters.
These are a recent thing, with the signature date on the board, these being '2019-11-14'.
https://www.ebay.com/itm/12-4G-option-frequency-counter-OPT-for-AGILENT-HP-53131-53132-53181/274130156096
https://www.ebay.com/itm/12-4G-Option-Frequency-Counter-Meter-For-AGILENT-HP-53131-53132-53181-dt55/174124120434
I'm fully across setting the scale to 4.0 in the math function, but can someone translate the Chinglish on these listings please;
attention:used this option,should be install 3G option,can test 2.0G signal.
Note:
- Please install 3G parts to your frequency meter first before applying our product, so that 2.0G signal can be measured.
Huh?
"3G parts" ???
Is this referring to the 030 option?
Wouldn't this be removed to make way for a 12.4 GHz board?
Although these BG7TBL products can be a bit hit & miss, has anyone fitted one of his 12.4 GHz prescalers to a bog standard HP Agilent 531xxA 225 MHz counter?
« Last Edit: January 21, 2020, 01:50:00 am by VK4GHZ »
Offline jadew
Re: HP Agilent 53131A 53132A 53181A 12.4 GHz option
« Reply #1 on: January 21, 2020, 02:32:54 am »
Hey,
Thanks for the e-mail!
I was kinda sleeping on this, because I don't have the documentation/video presentation/etc ready, but I have a 10 GHz option ready that works fine up to 11 GHz and with some limitation to 12 GHz.
It was meant to be a 12 GHz option, and it could have been, but after a couple of prototypes I realized that I can't take it there while retaining some of the key specifications, and without increasing the cost to what I consider to be too much.
Like I said, I don't have any documentation available at this time and only one prototype available, but I think I can start selling it within one or two days, since I'm ready for production otherwise.
In contrast to the chinese options, which I also noticed (they appeared a while after I announced my intention to develop a 12.4 GHz option):
- My option works directly, no extra scaling necessary.
- The maximum input rating is +27 dBm, ±35 V.
- Frequency of operation goes down to 100 MHz.
- Every board gets thoroughly tested and characterized.
- It will come with a high quality SMA connector, for the regular counters (255 MHz, 1.5 GHz and 3 GHz ones), https://cojotech.com/sma-bblk-2, or a high quality N-type connector for the ones that were originally fit with N-type connector (5 or the 12.4 GHz option).
- 2-year warranty.
I don't have typical data at this time, so please don't take it as such, nor as an indication for the minimal specifications, but this is what I measure on the prototype on my bench:
Freq (MHz)   Sensistivity (dBm)
100         -22 dBm
200         -30 dBm
500         -37 dBm
1000        -41 dBm
2000        -43 dBm
3000        -44 dBm
4000        -40 dBm
5000        -37 dBm
6000        -36 dBm
7000        -34 dBm
8000        -26 dBm
9000        -29 dBm
10000       -27 dBm
11000       -16 dBm
12000       -14 dBm
While the maximum input power is +27 dBm, across the board, the maximum input sensitivity is specified to +10 dBm (limited by signal generator), and the reason I'm not specifying this option above 10 GHz is because after 11.3 GHz, the maximum input sensitivity starts to drop slowly and reaches +2 dBm at 12 GHz.
Regarding the Channel 3 Guide - thanks about that, I'll have to clarify the text. The 225 MHz counters are actually the same with the 3 GHz ones, and they have no firmware limit.
Cheers
Edit: Increased exposure in one picture and removed a redundant word.
« Last Edit: January 21, 2020, 03:04:56 am by jadew »
« Reply #2 on: January 21, 2020, 04:08:28 am »
Hi Razvan
Thank you for picking up on this topic.  :)
I wrote 12.4 GHz only because of the original OPT 124's specified upper limit.
In real world use, there is a market out there among ham radio operators who, like myself, are on the 5.7 GHz and 10 GHz microwave bands.
A lot of these guys have will already have or appreciate getting one of these HP counters.
By the looks of your table above, sensitivity is good to 10000 MHz.
The 10 GHz ham band center of activity is 10368 MHz.
What is the sensitivity of your prototype at 10368, and say 10400 MHz?
Above 10400 MHz I doubt many hams would really care, so I wouldn't worry too much about that.
Those that might worry should probably be looking at a 20+ GHz counter anyway.
Hams with 24 GHz transverters often use an LO freq around 11-12 GHz (which is then doubled), so even if the counter's front end is a bit deaf, making any measurement at 12 GHz should be considered as a bonus!
Appreciate that, as the eBay lucky dip is always a concern.
Just to clarify, a standard 225 MHz 53181A with no optional 2nd channel will have no firmware limit like a standard 225 MHz 53131A with no optional 3rd channel?
I think you'll be on a winner here, compared to the vague Chinese crap on eBay that comes with little or no specifications.
Offline jadew
« Reply #3 on: January 21, 2020, 05:54:45 am »
Hey,
I'm not in my lab now, so I can't get the exact value at 10368 MHz, but at 10350 MHz it is -20 dBm and -18 dBm at 10400 MHz.
That is correct, yes. As far as I'm aware, only the 1.5 GHz and the 5 GHz ones were firmware limited, as they were using the same 3 GHz and respectively 12.4 GHz options, that were present on the non limited variants.
Cheers
Offline Helix70
  • VK4JNA
« Reply #4 on: January 21, 2020, 08:20:38 am »
What will you do with you 1.3Ghz option for the 5315A?? I have one of these counters, and am missing the 1.3Ghz option. Are you interested in selling it?
Josh VK4JNA
« Reply #5 on: January 21, 2020, 08:50:19 am »
Hi Josh.
PM sent about that.
Off topic, but you may be interested in some HP 5315A mods I have done;
http://vk4ghz.com/hp-5315-ext-10-mhz-ref-mod-2/
http://vk4ghz.com/grafting-a-fluke-tilt-bail-onto-a-hp-5315a/
Offline jadew
« Reply #6 on: January 25, 2020, 12:51:46 pm »
Alright, first batch is done and up for sale, with a limited-time 10% discount.
Datasheet: https://cojotech.com/media/datasheets/HPO-100%20-%20Datasheet.pdf
Product page: https://cojotech.com/hpo-100
As you'll see from the datasheet I'm only specifying it to 10 GHz, but as discussed above, it extends past that, but that is not guaranteed in any way and the maximum input sensitivity (not the damage level) gets lower as the frequency increases. I might demonstrate all this in a video soon.
Also, I wanted to mention that an S variant is possible, which would have higher sensitivity (5 to 10 dB), but at the cost of triggering constantly. The regular version doesn't (I think that's another difference between this one and the chinese stuff). So if anyone is interested in that, I can make them on request, at no extra cost.
The following users thanked this post: Qw3rtzuiop
Offline bson
« Reply #7 on: January 25, 2020, 11:27:18 pm »
Order placed!
Offline jadew
« Reply #8 on: January 26, 2020, 02:14:43 am »
Order placed!
Thank you! I will dispatch it on Monday.
Offline EV
  • Aficionado
« Reply #9 on: January 26, 2020, 09:38:36 am »
I placed order also!  :)
Offline jadew
« Reply #10 on: January 26, 2020, 09:47:40 am »
Thank you! :)
That was the last one.
Edit: I enabled preordering for anyone still interested. Lead time: 1-2 weeks, but qty will be limited.
« Last Edit: January 26, 2020, 10:04:56 am by jadew »
Offline EV
  • Aficionado
« Reply #11 on: January 29, 2020, 03:53:33 pm »
I got the board today.  :) It works fine from 60 MHz up to 8 GHz and maybe over it but I can not go higher with my generators.
Offline jadew
« Reply #12 on: January 29, 2020, 05:49:58 pm »
Glad to hear that it's working.
I don't know if you caught that, but at the time when I sent you the link to the installation instructions, there was a part missing about tightening the screws :) It's fixed now, but in case you thought they have to be left loose - they shouldn't.
Offline EV
  • Aficionado
« Reply #13 on: January 30, 2020, 02:26:04 pm »
I tightened the srews of course. I did not read much instructions, it was so easy.
... in case you thought they have to be left loose - they shouldn't.
Offline jadew
« Reply #14 on: January 30, 2020, 02:30:09 pm »
Heh, that's good. I was worried because I put a lot of stress on not warping the board too much, and was afraid that it read as if the screws can't be tightened at all.
Offline EV
  • Aficionado
« Reply #15 on: January 31, 2020, 11:03:37 am »
I measured the sensitivity of this HPO-100 with HP 8642A signal generator. It goes only up to 1 GHz and its calibration date has expired.
   50             -17 dBm
  100            -24 dBm
  200            -30 dBm
  300            -34 dBm
  400            -36 dBm
  500            -38 dBm
  600            -39 dBm
  700            -40 dBm
  800            -39 dBm
  900            -41 dBm
 1000           -40 dBm
Offline jadew
« Reply #16 on: January 31, 2020, 12:17:43 pm »
@EV, my test report shows similar values for your board, ± 1 or 2 dB at some frequencies, but it sounds about right.
Be careful about the 50 MHz result tho. At that frequency it doesn't operate correctly around the -4 dBm power. This is a design limitation and not particular to your board, and it's why I'm only specifying it from 100 MHz up, but I know how it can be misleading.
Offline EV
  • Aficionado
« Reply #17 on: January 31, 2020, 01:48:07 pm »
I have no problems with HP 8642A signal generator on any signal level I tried between 36 - 100 MHz (sine wave).  On 36 MHz sensitivity is -13 dBm.
With WB-SG1 Wideband Signal generator there are problems between 36 - 80 MHz square wave signal. Its level is 0 dBm. Here is picture of its 50 MHz signal:
« Last Edit: January 31, 2020, 02:04:01 pm by EV »
Offline jadew
« Reply #18 on: January 31, 2020, 01:56:32 pm »
@EV, that's good then. The deviation I measured was very small to begin with, so it's possible it's not there for your board.
« Last Edit: January 31, 2020, 01:58:40 pm by jadew »
Offline Stray Electron
« Reply #19 on: January 31, 2020, 07:13:28 pm »
Hey,
Cheers
  I have been offered a 1.5 Ghz HP 538181A with the 010 High Stability time base. If I understand your statement correctly then the only change that would be needed to bring it up to 3 GHz is a software change. Do you know what would be needed to change the SW?
Offline bson
« Reply #20 on: January 31, 2020, 07:15:55 pm »
Got mine too!
I can only test it up to about 3.5GHz since that's the limit for my HP 8133A pulse generator, but that all works fine.  It's nice to replace the BNC input of the OEM 3GHz board with an SMA connector.  I didn't check how the jitter compares to the OEM, but it's quite possible this board performs better also at frequencies where it overlaps the two regular channels on my 53131A.
I also didn't check the instructions; installation is trivial.
Good stuff! :-+
Offline jadew
« Reply #21 on: January 31, 2020, 09:33:34 pm »
I didn't need to do it myself yet, but I have come across several discussions on the topic. You will have to pull out one of the ICs on the mother board, read it, patch it, and put it back. Don't know what keywords to give you, but I'm sure google's AI will be more than willing to help :)
Got mine too!
Good stuff! :-+
Thanks for the update! Was wondering if you got it working.
I agree about the SMA. It's one less adapter that I have to use.
« Reply #22 on: January 31, 2020, 10:31:48 pm »
Hey,
Found on Groups IO:
Ok, I here is the updated process which includes the upgrade/downgrade offsets & values for the 53181A & 53132A.  They're identical values, so they SHOULD work with a 53131A.
 1) Remove the existing 3rd channel, if it exists
 2) To add 5/12GHz module, install Zero Ohm resistor in R334 position (located on underside of mainboard near J6).
     To replace 5/12GHz module with a 3GHz module, remove R334.
 3) Remove U14
 4) Read U14 via EPROM burner
 5) Validate that header of data says 'HP53131 is a winner!' (it says this for 53131A/53132A/53181A)
    * Be 100% sure the read is good.  Some unit-specific cal data is on this.  Maybe read it a few times and with
    multiple burners if available.  Verify the checksum doesn't change on several reads.  Place the checksum in the
    filename when you save it, so you know what it is supposed to be in the future.
 6) Install socket in U14 location.  Insert the original unmodified EEPROM into the socket and power on
    to ensure there are no errors (leave the 3rd channel OUT during this test).  You just want to make sure
    the counter can fire up without errors.   Once you're sure the socket installation is working well, remove the
    EEPROM and proceed.
 7) Using a hex editor of your choice, change the following offsets to the indicated values:
For 12GHz module:
Offset 0x01, Value 0x30
Offset 0x1b, Value 0x03
Offset 0x1c, Value 0x04
For 3GHz module:
Offset 0x01, Value 0x2F
Offset 0x1b, Value 0x02
Offset 0x1c, Value 0x01
 8) Erase the factory EEPROM, or use another equivalent one, and burn the new version with the changed bytes.
 9) Insert modified EEPROM in the newly installed socket
10) Install the appropriate 3rd channel prescaler (12GHz/3GHz)
Power On and watch for errors.  If any errors come up, the ROM info is bad or not being read correctly. Re-socket the chip, re-burn, check solder job, etc.  There should be NO errors.
Not entirely sure why one would want to do this, but the following values are to digitally limit the 12GHz prescaler to 5GHz:
Now, if you have a 1.5GHz or 5GHz optioned unit, simply changing the EEPROM values to the 3GHz or 12GHz values (respectively) will upgrade that unit without any additional hardware
Happy Counting!
Colby
K6RKE
The following users thanked this post: edavid, Stray Electron, ytsejam, TomT
Offline Helix70
  • VK4JNA
« Reply #23 on: February 01, 2020, 12:42:12 am »
Hi Josh.
PM sent about that.
Thanks,
My bail is working, and I have fitted a 10Mhz Movion OCXO module to a PCB from amc184, designed for the 5315A/5316A. When I check with my GPSDO, it is still within 0.1Hz after 12 months. I really like the 53131A/53132A/53181A machines, especially with 3+ Ghz channel upgrades, keeping my eyes open for a great price.
« Reply #24 on: February 01, 2020, 12:51:23 am »
   Thanks Colby!  One question, can the 1.5 be upgraded to 12.4GHZ by SW alone?  I thought that the 1.5 and 3 GHZ models used one prescaler board and the 5/ 12.4 GHz prescaler used a different board.  Or is the only difference between the boards RF input connector? (type N instead of BNC).
