Hey,
I have been offered a 1.5 Ghz HP 538181A with the 010 High Stability time base. If I understand your statement correctly then the only change that would be needed to bring it up to 3 GHz is a software change. Do you know what would be needed to change the SW?
Found on Groups IO:
Ok, I here is the updated process which includes the upgrade/downgrade offsets & values for the 53181A & 53132A. They're identical values, so they SHOULD work with a 53131A.
1) Remove the existing 3rd channel, if it exists
2) To add 5/12GHz module, install Zero Ohm resistor in R334 position (located on underside of mainboard near J6).
To replace 5/12GHz module with a 3GHz module, remove R334.
3) Remove U14
4) Read U14 via EPROM burner
5) Validate that header of data says 'HP53131 is a winner!' (it says this for 53131A/53132A/53181A)
* Be 100% sure the read is good. Some unit-specific cal data is on this. Maybe read it a few times and with
multiple burners if available. Verify the checksum doesn't change on several reads. Place the checksum in the
filename when you save it, so you know what it is supposed to be in the future.
6) Install socket in U14 location. Insert the original unmodified EEPROM into the socket and power on
to ensure there are no errors (leave the 3rd channel OUT during this test). You just want to make sure
the counter can fire up without errors. Once you're sure the socket installation is working well, remove the
EEPROM and proceed.
7) Using a hex editor of your choice, change the following offsets to the indicated values:
For 12GHz module:
Offset 0x01, Value 0x30
Offset 0x1b, Value 0x03
Offset 0x1c, Value 0x04
For 3GHz module:
Offset 0x01, Value 0x2F
Offset 0x1b, Value 0x02
Offset 0x1c, Value 0x01
Erase the factory EEPROM, or use another equivalent one, and burn the new version with the changed bytes.
9) Insert modified EEPROM in the newly installed socket
10) Install the appropriate 3rd channel prescaler (12GHz/3GHz)
Power On and watch for errors. If any errors come up, the ROM info is bad or not being read correctly. Re-socket the chip, re-burn, check solder job, etc. There should be NO errors.
Not entirely sure why one would want to do this, but the following values are to digitally limit the 12GHz prescaler to 5GHz:
Now, if you have a 1.5GHz or 5GHz optioned unit, simply changing the EEPROM values to the 3GHz or 12GHz values (respectively) will upgrade that unit without any additional hardware
Happy Counting!
Colby
K6RKE
