Author Topic: HP AGILENT E4433B ESG-D SERIES SIGNAL GENERATOR 250KHZ-4.0GHZ  (Read 13287 times)
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
Re: HP AGILENT E4433B ESG-D SERIES SIGNAL GENERATOR 250KHZ-4.0GHZ
« Reply #25 on: January 19, 2023, 05:14:22 pm »
Was chatting with a guy from Keysight and he suggested changing the SICL address from the default "gpib0" to "hpib7" - That solved the problem:
Service software now running.
TonyG
The following users thanked this post: colorado.rob
Offline mbielman
« Reply #26 on: April 29, 2023, 07:58:44 pm »
sayu asked: "Wonder if anybody have the code so that I can adjust (correct) the output level at 3-4GHz. My unit tend to drop 2dbm at 4GHz when measure with a power meter."
I have the same issue/question.
Thanks!
Offline mankan
« Reply #27 on: May 01, 2023, 09:13:10 am »
Have a look here.
Offline romal76
  • Country: ru
« Reply #28 on: May 10, 2023, 06:34:12 am »
may be it still actual )))
