Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
HP E4432B Signal Generator
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: HP E4432B Signal Generator (Read 1030 times)
MaxFrister
Regular Contributor
Country:
on:
March 22, 2023, 05:33:23 pm »
I have a new-to-me HPAK E4432B signal generator that I bought broken. I've cleaned it up and have it limping along.
I am waiting for a ccfl and bnc connector and trying to figure out what to do about the missing tooth.
In the meantime, I’m trying to figure out how to use it and have some questions.
Is there any particular reason to update the firmware? I’m always a little reluctant with such an old device.
Is the hardware the same between the E4432B (3GHz) and E4433B(4GHz) versions. Is there a downside to hacking it for the higher bandwidth?
Is there any software for the generator and/or UND option that runs on a modern computer. The only software I’ve seen seems to require windows NT or similar which I really don’t want to ever see again.
TIA
Logged
Kim Christensen
Super Contributor
Country:
Re: HP E4432B Signal Generator
Reply #1 on:
March 22, 2023, 07:11:10 pm »
Yea, I'm always a bit leery about firmware updates. I'd check the version # you have and then check what the update # is and what it gives you. An update may not give you anything of value to you.
I doubt you can just software hack it without a hardware update.
You can always control it via GPIB or the serial interface if it has those options installed. (Look into the free version of LabView, or the equivalent Open source software)
Last Edit: March 22, 2023, 07:23:31 pm by Kim Christensen
Logged
MaxFrister
TheSteve
Supporter
Country:
Living the Dream
Reply #2 on:
March 23, 2023, 07:44:39 pm »
I always prefer to run the newest firmware and did update my E4431B.
Yes, a firmware only hack will take it to 4 GHz. If done properly the only possible downside is that the amplitude will likely be a little low between 3 and 4 GHz(for your model) as that portion will not be calibrated.
Logged
VE7FM
MaxFrister
dxl
Regular Contributor
Country:
Reply #3 on:
March 23, 2023, 07:54:05 pm »
I upgraded mine a while ago to 4GHz and haven't found a problem. I wrote a little script to calibrated the upper band that wasn't present before:
https://github.com/svenschnelle/caltools/blob/master/calesg.py
It uses a E4418B power meter to do so, but i could be adapted to other types if needed.
Logged
bingo600
edavid
TheSteve
MaxFrister
WernerFalken
Contributor
Reply #4 on:
July 06, 2023, 05:30:52 pm »
Has anyone written code to add license options? One other downside to changing the model #, iirc, is that some license options become invalidated.
I haven't looked very much, yet, but I am looking for a license gen....
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
