Author Topic: HP ESA-L1500A SA TG opinions  (Read 973 times)
Offline wd5jfrTopic starter
« on: June 13, 2020, 04:44:54 pm »
I've been considering something like this because it  goes to 1.5 GHz and covers  ham bands thru 33 and 23 cm. ( I have an Agilent E6380A which skips 23cm/1240 MHz.)  Use will be for sweep filters, check antennas and trouble shooting in the HF & VHF bands as well.  What are the pros and cons?  Also what are  other not quite boat anchors to consider and not spend $1000.00 that have a reliability track record?
I'd like to get the  Siglent SSA3032 and could stretch my budget but have a hard time justifying the expense.  Aside from its' features, specs, and size it has a 3 yr warranty and my credit card doubles manufacturers warranties.  So in the end this might make more sense if I wasn't trying to be thrifty.
One of my friends suggests considering a Rohde FSH3 instead of the Siglent???
I should mention that I've had 2 different  HP 141 & TG, an old Advantest can remember model but it wouldn't stay working, Anritsu MS2670A and now HP 8935. I'm nearly 79 so this will be my last SA if I can figure out which one meets my fancy.
Thanks
Hank
« Last Edit: June 13, 2020, 08:37:48 pm by wd5jfr »
Offline Marcel G
Re: HP ESA-L1500A SA TG opinions
« Reply #1 on: June 14, 2020, 06:20:42 am »
Please don't buy R&S FSH 3 or 6.
This device is the first portable that they released.
Problems:
1: Battery and circuit
2: Poor display
3: Small dynamic range
4: Noisy trace with TG
5: Phase noise
The FSH 4 is a lot better in that respect, but no world wonder either.
I had both devices (FSH 3.23 and 4.24) but will not buy them now.
My advice forget that very small stuff but buy a bit bigger (the keysight Fieldfox series is an exception to this).
I have an Agilent ESA E4411B now is nothing special but does not know above mentioned problems.
I have no experience with the Chinese Siglent (plastic segment) Spectrum/Network analyzers.
« Last Edit: June 14, 2020, 06:33:35 am by Marcel G »
« Reply #2 on: June 14, 2020, 04:30:21 pm »
OK, thanks, I appreciate the help and candid comments.  The Rohde FSH3 is off my list and will also check out the Agilent ESA E4411B and look for 50 ohms.
Thanks
Hank
